Windows 7: Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
26 Aug 2014   #1
JKalts
Windows 7 Home Premium SP1 x64
Cheers all,
Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I haven't checked yet)...
  • Opening a Program
  • Opening a Folder in Windows Explorer
  • Starting a new Windows Explorer Session
  • Closing a Window (expected function)
  • Closing a Windows Explorer Session (expected function)
Those not followed by (expected function) have a different sound assigned to them, although the Close Window sound plays anyways. Not always immediately after the action is performed, either - there can be anywhere from a 1 to 15 second delay before the .wav plays.
The sounds are located in C:\Windows\Media\AltimitOS\ with AltimitOS being a custom folder I copied in. I originally untar'd everything to the desktop, then created and moved everything into the folder and tried running the theme from there. I've made sure all file paths are leading to the \Media\AltimitOS folder.
Any help is appreciated. Cheers,
-Kalts.
27 Aug 2014   #2
fireberd
As this is a 3rd party app, it sounds like it is buggy. Does the Windows schemes work OK? If so, that puts it back to the buggy app.
I would go back to the app developer for assistance.
27 Aug 2014   #3
JKalts
Cheers,
Only thing I downloaded was the .wav files; I had to manually set up the sound scheme from there through Personalization. I checked every file to make sure it worked, once through Media Player, and again through the Test button. I also double-checked the scheme and made sure that the sound I assigned to Close Window was only assigned to Close Window.
I'll do some testing with the other built-in Scheme later today and edit this with the results. Oddly enough, even with System Sounds muted, the custom sound for the Windows UAC plays (after allowing or denying the program, however, the Close Window sound plays ~4 times), and the sounds assigned to Device Connected and Device Disconnected work as well.
EDIT: All other sound schemes work as expected; it's only this custom scheme that's I'm experiencing issues with. Could it be a .THEME edit error, or maybe something solvable through the registry? Should I post the variables assigned to the AltimitOS registry cluster?
04 Sep 2014   #4
JKalts
Bumping this due to lack of follow-up.
Win 7 making sound on login sound scheme is set to none
I think the title says it all, when I log into Windows 7, it sitll makes a sound upon login even though sounds are set to none. Thanks in advance for any assistance.
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
Sound Scheme Changes
Running Windows 7 Pro I have created a sound scheme, named it and saved it. However, after every 2 or 3 boot-ups it reverts to the Windows Default scheme. How do I keep my scheme constant without Windows Default taking over? Thanks.
Win 7 changed my chosen sound profile
When I installed and set up set up Win 7 several weeks ago, I chose "no sounds." Yesterday or the day before, it switched itself back to "Windows default." I did not make any changes myself to Sound. Anyone know why or how this happens?
windows 7 sound scheme
Hi all, Not sure what exactly happened! After installation the windows 7 and start installing the required and needed softwares Appears that Start negotiator sound gone! and whenever you click on any of programs no sound comes out!! this is happened twice for me Is there any way that i can...
Can you have 2 different sound scheme's
Does anyone know if you can save two different sound schemes? In other words, save some sounds with "windows default" and other sounds with a different sound scheme (control panel, sound, sounds tab, sound scheme). Thanks
