Windows 7: Lost Sound after Power Shortage
10 Sep 2014   #1
Omarrrio
Hi everyone, I forgot my laptop in sleep mode yesterday, and since my battery is dead, someone from the house removed the AC Adapter and the PC turned off, when i turned it on this morning, there was no sound, there is no red cross on the sound icon in the notification bar, that one is fully functional as i can increase/decrease volume, but there is no sound coming of the speakers, i tried with my headphones, but still nothing, I've checked my Control Panel and the speakers are already set to default, but nothing comes out, i also tried uninstalling and reinstalling the drivers, and the problem persists, i rebooted 7 times to no avail, can anyone help me on this matter ? I did however find a temporary fix, going to the bios and "Save settings then Exit" seems to get the sound back but, every time i shut my computer down completely, the sound is lost and i have to do the fix again.
I use a Intel Core i3 M380 DELL INSPIRON N5010 running Windows 7 ultimate x64 bits on 4GB of ram, Intel HD Graphics 2000, my Sound Card uses IDT High Definition Audio Codec that i got from Dell's Website. If you guys need any more info please let me know I'll be monitoring this thread by the second.
10 Sep 2014   #2
fireberd
A power failure (what you had) can cause untold damage, from just a corrupted OS/hard drive to actual hardware failures.
There should be Dell diagnostics installed on the hard drive (I think accessed by F12 at power on), run the hardware diagnostics as a first step.
If the hardware diagnostics pass, the next step is to use the System Restore function and restore the PC back to an available restore date that is PRIOR to the power failure issue. System Restore can be accessed from Start/Programs/Accessories/System Tools. System Restore will not delete any user data.
If that does not fix it, unfortunately the next step is to use the Dell PC Restore (accessed by F8 at power on) and restore the PC to the original factory setup.
Corrupt Os When Lost the Power?
Hi, I am using Windows 7 Home premium 32 bit since 3 years in my acer laptop . It was battery problem without power source can not stand by on battery . When it was Shut down power lost it can't load os, it shows empty then i need to install new os . Can i solve this problem and how please...
General Discussion
Lost Power, PC won't boot into Windows 7
After countless searches I finally decided to post here as Im about to give up. My computer shut down suddenly and upon powering it, it says windows must do start up repair. Whenever start up repair is initiated, it just says searching for problems and does that forever (well ive left it...
Backup and Restore
Report: Brace Yourself for a Hard Drive Shortage
Read more at: Maximum PC | Report: Brace Yourself for a Hard Drive Shortage
News
Lost power on install!
Ok. I was installing windows 7 when I was almost complete and the power went out in the house from a storm. I tried reloading windows and it went back to install and said because it shutdown I had to restart to reinstall and it did and still gives me the same message. I did a upgrade and I dont...
Installation & Setup
Desktop Functionality Lost in Power Outage
Hello everyone, I've had Windows 7 Evaluation copy (Build 7100, x64 edition) installed for a while now and it has worked great--I really like it! However, this morning I had a quick 5 second power outage, and when I booted my PC the desktop no longer worked! All of the icons I had on desktop are...
General Discussion
