Hmmm yes I have changed my board and it was Gigabyte having the VIA audio codec. So I performed a clean format while shifting from the mobos. I am currently downloading the drivers from the address you have given. I ll report back soon. Thanx for your concern and will definitely scale you up even if the problem doesn't gets solved. I ll report back in few minutes.
No luck! I wonder how my front panels audio work fine.
Is this surround sound your trying to get working if so, To configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.
