One sided audio from rear panel.
Page 2 of 2 FirstFirst 12
  1. Posts : 19
    HarriePateman said:
    Once you have installed the drivers, see if it works?
    If not go to realteks website and reinstall the drivers you need.
    I tried that now but still the same. Pissed off on this problem. One said that blow some air into the rear panel.
  2. Posts : 3,904
    Windows 7 Ultimate 64-bit
       #12
    That can help as it could be a dust build up.
    You mentioned you have changed the board?
    And you have this installed?
    Realtek Definition Audio Codecs
  3. Posts : 19
    Hmmm yes I have changed my board and it was Gigabyte having the VIA audio codec. So I performed a clean format while shifting from the mobos. I am currently downloading the drivers from the address you have given. I ll report back soon. Thanx for your concern and will definitely scale you up even if the problem doesn't gets solved. I ll report back in few minutes.
  4. Posts : 3,904
       #14
    Brilliant thank you
  5. Posts : 19
       #15
    No luck! I wonder how my front panels audio work fine.
  6. Posts : 3,904
       #16
    Is this surround sound your trying to get working if so, To configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.
  7. Posts : 19
       #17
    No. I am trying to get stereo sound. But when I partially insert the jack I get mono(centered) audio which is not so clear. I have 2.1 channel Creative speakers so should I need to enable multi-channel audio? I am not able to find it in Realtek HD Audio.
