Windows 7: realtek high definition audio and high definition audio device problem
15 Sep 2014   #11
judymum
windows 7 64bit
On restart there is sound again so fingers crossed! Until I've had it on and off a few times I'm unsure if fully solved though until I see if that high definition audio device automatically installs again which hopefully it won't.
I'll just wait to hear what to choose for the AMD installation and then I'll start to turn on and off a few times! Thank you
15 Sep 2014   #12
judymum
windows 7 64bit
I read around and realised I needed to choose express so the AMD had installed now. I haven't checked if the audio is working with the HDMI cable yet though. But unfortunately the sound problem is still the same :-(. I shut down the laptop and on restart it automatically installed the high definition audio device and no sound. Shut it down again and the realtek was back and sound working again, so it seems its still going to do the every other time thing of installing this high defintion audio device automatically. Very grateful for any more tips!
15 Sep 2014   #13
fireberd
Choose Express for the AMD install.
Doing what you found on another site, could negate what help I'm trying to give you.
15 Sep 2014   #14
judymum
windows 7 64bit
OK sorry - I am really grateful for your help - so I've just tried to re-install the realtek again in the original way without disabling those 2 options I read about and even though I clicked yes still I get the error code I got the first time which is 0001 (and says install realtek HD audio driver failure!!)
15 Sep 2014   #15
fireberd
I'm not sure what your status with the sound driver is now. I try to avoid suggesting a reinstall, but sometimes it takes that to get everything resolved. Reluctantly I'm going to suggest that with this.
HP has a video on doing a reinstall or "Recovery" as they call it. But, before you do the "Recovery" you need to back up any user data to some other media, such as a USB flash drive, CD/DVD's as user data will most likely be lost in the Recovery.
Compaq Presario CQ58-140SM Notebook PC | HP® Support=
15 Sep 2014   #16
judymum
windows 7 64bit
OK thank you for your help and time. I think I'll just continue uninstalling the high definition audio device for now which then gives me sound on the next restart as I can't face doing the recovery and possibly losing everything on the laptop at the moment but will look at it at some point. Thanks again!
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
conexant high definition audio and intel(R) High Definition Audio HDMI
i have a gateway computer and i want to record some audio from my computer. i looked online how to do this and stereo mixer kept coming up. i looked in my sound and show disabled and disconnected devices are both selected and i do not see stereo mixer in the list of recording devices. can someone...
Realtek High Definition Audio problem
I have a new Dell PC that has Realtek High Definition Audio. As best as I can describe it, while watching videos or in a game, it periodically and with no particular intervals of time, will momentarily (no more than a second) pause and I'll hear a buzz. It then carries on as if nothing had...
realtek high definition audio device - no sound
Hi, I just got a new PC and I can't get the sound to work. My PC has the following specs: Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) DirectX Version 11.0 CPU Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Mainboard Model ...
5.1 Sound doesnt work at Realtek High Definition Audio Device
Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is...
Hi guys..now we all know ...this is golbal problem..i have instaled my windows 7 ultimate x86 and no drivers works for me...like always :Code 10 problem ...last time ..a xp driver works ...but i can't remember the version that i used... Maybe this will help you...
Drivers
