Windows 7: Sound stops working randomly after a while
15 Sep 2014   #1
cykelmyggen
Windows 7 Home Premium 64-bit
Hi
I've bought a set of new speakers for listening to music on my PC. However they stop playing randomly after a while. If I then go to the Device-manager and rightclick on the speakers (which is set as the default Device for sound) and do the test it works again for a while, whereupon the pattern repeats again.
First I used The built-in Realtek HD audio on my ASUS MB, and then I installed a Creative SB Audigy 2CZ sound card to see if it had anything to do with the Realtek-setup, but the patterne is the same.
Before I bought the speakers I uset my Headphones and never experienced these kind of problems.
Any help to get on with this would be appreciated.
15 Sep 2014   #2
fireberd
First, if you installed a separate sound card, you must disable the on-board (RealTek) in the BIOS or they can conflict, and could even possibly cause the problem you are having.
Second, your "sound card", as listed in your specs is NOT the NVIDIA High Definition Audio, that is ONLY for HDMI audio.
Your sound card would be the SoundBlaster Audigy, if its still installed.
15 Sep 2014   #3
cykelmyggen
Forgot to write that I disabled Realtek in BIOS, sorry.
Problem was also present when I was running Realtek with no Audigy drivers installed.
I just tested again with headphones connected in stead of speakers and problem was not present - reoccurs when speakers are connected.
15 Sep 2014   #4
fireberd
As the same problem is happening with both RealTek and the SoundBlaster, that says the sound devices are working and its something else in the PC that is causing the problem.
Do you have Skype or some gaming program (e.g. Steam) installed? Could it be they are causing the playback device problem?
15 Sep 2014   #5
cykelmyggen
No, I don't have either of those programs installed.
Just found out that when I'm palying music in Winamp I can "wake up" the spekers by adjusting the volume or by clicking the sound on/off in the same program.
Sound on Laptop and Desktop Randomly Stops Working and Working
So recently the sound on my desktop and my laptop has stopped working. For seemingly no reason. I really don't understand it. I first noticed it with my desktop. The sound just randomly stopped working. But not...entirely. It's really strange and complicated what's been happening, so bare with...
Sound Randomly stops
Hi people. Having an annoying issue that's started occurring the last couple days. As the title says my sound is dropping out at random times. I've noticed it has occurred when my computer stops performing a task with sound. It has stopped after playing a game, watching a movie and listening to...
Hi, My acer (aspier v5 171 Series) (windows 8) has been working smoothly for 1 year now, but since couple of days the sound would go off if something is not being played for sometime. then I need to restart to get it back...initially I though it happens after I lock the laptop but today it went...
Keyboard randomly stops working
So i have windows ultimate 32 bit, and i noticed this problem. My keyboard randomly, doesnt matter what im doing, stops working. All i hear is a beep and then the keyboard is frozen. Sometimes i can go into on-screen keyboard and press a few buttons and my keyboard will unfreeze, but sometimes i...
Hardware & Devices
Internet stops working randomly
Hi, I have a fresh install of Windows 7 on a (partly) new Desktop. Sometimes suddenly internet gets really slow and stops working. All other devices in my house (ipad, labtop (XP), phones) have no problems at all. This should suggest it's a problem of my PC but: Connecting to the WiFi of my...
Network & Sharing
Keyboard randomly stops working.
Hi thelastbonbona, It may not be an issue with the keyboard at all. You may try using a good-known keyboard with the system, if available; will help you to isolate the keyboard as the possible root cause. Alternatively, you may use this keyboard with another system to see if the issue...
General Discussion
