Windows 7: no audio output device is installed
21 Sep 2014   #11
rvcjew
7 Pro x64, 10 Pro x64
is it an Dell Inspiron 1520 and looks like this? http://www.notebookcheck.net/uploads...3fd7297321.jpg Also does it have vista on it and if so what version? EDIT: if its a Dell what is your SERVICE TAG, its on the sticker with model info.
21 Sep 2014   #12
claudiay
ufff i don t know....
Yes, it is a Dell Inspiron 1520, Service Tag: J1BPC3J Express service code: 41438988415
21 Sep 2014   #13
rvcjew
21 Sep 2014   #14
claudiay
Waaaouhhhh, it work's again !!!! I have sound again !!! I m soooo happy )))) I want to thank you very very much !!! you guided me very good in this PC dschungel !!!! I wish you a very happy and lucky day !!!! All the best to you.
Claudia
21 Sep 2014   #15
rvcjew
Haha, no problem you should on the top of the thread mark it as solved so others know there is a solution in it. and you can click the scales on top of my posts to recommend me if you want. Have fun with your working pc.
21 Sep 2014   #16
claudiay
Quote   Quote: Originally Posted by rvcjew View Post
Of course I want to recommend you !!!! but where??? I give you 10/10 or 20/20, what ever you like best))
21 Sep 2014   #17
rvcjew
Quote   Quote: Originally Posted by claudiay View Post
lol you just click these scales and thanks its the though that counts. You can do it to anyone that helps you.
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
