Windows 7: Mic not working while using Steelseries usb sound card and headphones
25 Sep 2014   #11
fireberd
I had THX Tru Studio that came with one of the desktop motherboards I have. It was installed without problem, with all the other motherboard software.
There is probably something missing on your system.
13 Nov 2014   #12
tvinther
Windows 7 Ultimate x64; Windows 8.1 Pro
The Steelseries USB Sound Card records the sound on the right channel and if your microphone is only connected to the left channel, it will not Work. it is standard to short circuit the left and right channel in the mini-Jack connector for mono microphones, but some headset manufactures do not do that.
I solved the issu by connecting the left and right channel at the mini Jack connector inside the USB soundcard.
I hope this helps you?
Sound through headphones not working after sleep
Hi, I have recently updated my realtek audio drivers to the latest version on my acer laptop. But now after my computer comes out of sleep mode, I can't hear anything trough my headphones. When I unplug them, the sound is just fine. I have line in headphones, not USB. The only way to get them...
Sound card problem - headphones work, notebook speakers don't
Hi all, I just bought an old Toshiba A210 laptop and I'm dealing with a couple of (minor) problems. As the title says, I've tried every conceivable control, I can't get any sound from the speakers. No hissing sound, nothing, completely silent. Headphones work fine though. I checked device...
Computer thinks it has no sound card unless headphones plugged in
Unless I have speakers or headphones plugged in, my computer gives me the red "X" over my sound icon in my system tray, and anything that involves sound won't work. This is annoying because I don't always want to listen to sound at work, but I still need to be able to play things that have sound...
Best SteelSeries Siberia uSB sound card settings?
I have disabled Realtek onboard audio in device manager, should i also disable AMD HD audio device..what is it for? I have no other digital devices,just the 2.1 speakers.
SteelSeries USB Siberia Sound Card Problems
Hello... so i bought a pair of Siberia V2's (black version) and later i bought the card itself (black version) so here is the problem since i play a lot of Counter Strike from time to time my left and right channel swap and that's a really big problem and there's this other problem from time...
Sound card controls only headphones, not speakers!
Hi. I have a sound card problem after I installed Windows 7. Previously I had Windows XP and after I replaced OS some days after I noticed something weird - I can control headphones ONLY (volume, balance etc.) but my built in speakers are living completely independent life.:shock: If I`m playing...
