Windows 7: Mic not working while using Steelseries usb sound card and headphones
25 Sep 2014   #1
jar
Windows 7 Ultimate 64 bit
Hello, I decided to make a post here since I'm losing my mind and I hope somebody will be able to help me.
Yesterday I've got my hands on Siberia USB soundcard, one like this:
SteelSeries - Gaming Headsets - SteelSeries Siberia USB Soundcard
I'm currently using headset made by the same company:
SteelSeries - Gaming Headsets - SteelSeries Flux In-ear Pro Headset
The problem is as follows: I've installed all drivers and connected usb card to my pc (laptop by the way) and headset to the sound card. Sound works fine, the mic shows up in recording devices but it doesn't register any sound. When I connect headset directly to my laptop mic works fine.
I've tried tampering with all possible setting but no luck, also when I connected my very old mic to the sound card it worked just fine. A little bit of irony that steelseries product doesn't work with another steelseries product.
If you have any idea what's going on please help, thank you
25 Sep 2014   #2
fireberd
Is the Siberia USB sound card set as the default recording device? As the PC sound card works, that says the PC sound card is set as the Default recording device.
As you are using a separate sound card, the PC's sound should be disabled in the BIOS so it does not conflict and interfere.
25 Sep 2014   #3
jar
I could try tampering with bios but if that was the case my old mic wouldn't work either right? Thing is it does and that confuses me.
headphones themselves aren't broken too since they work when connected directly.
25 Sep 2014   #4
fireberd
Generally, you want the on-board audio disabled. Windows can only have one default playback device. e.g. your PC sound card or the USB sound card. Recording, your Steel Series USB needs to be enabled in the Sound Panel/Recording section for it to work. And, if the on-board sound's Stereo Mix is set as default then the Steel Series mic may not be heard. As noted the conflicts and confusion. By only having one it eliminates conflicts from the other.
25 Sep 2014   #5
jar
Just tried what you suggested but it didn't solve problem. I'm starting to think this is some sort of strange hardware issue since I hear strange noise and cracking when I enable[listen to the device]. Probably this sound card is just bad quality but maybe there is something else I didn't think of.
25 Sep 2014   #6
fireberd
Is the Siberia USB card really better than the sound card in the PC? Do you really need it?
25 Sep 2014   #7
jar
I got it for free so decided to try it Sound quality in my pc is decent apart from very quiet noise when nothing plays but mic quality is worse, it's manageable but sometimes annoying for people I talk with (mostly due to the fact that mic picks up some static when it is connected directly to laptop). This is laptop I'm using:
MSI Global GT780
I remember trying to do something with audio drivers when I got headset but quality didn't improve much unfortunately.
25 Sep 2014   #8
fireberd
That looks like a very nice gaming PC. It says Windows 8. Did you downgrade to Windows 7? And if that is the case maybe all the extra audio software, such as the THX Tru Studio was not installed?
25 Sep 2014   #9
jar
It actually came without any OS, I installed all drivers myself from msi website. To be frank I completely forgot about THX, I'll try installing them now and see how it turns out.
25 Sep 2014   #10
jar
nvm^, for some reason I can't install THXTruStudio PRO downloaded from official msi website, nothing happens or error "this software may not be installed properly" pops up- guess there's nothing more I can do, I'll do a fresh installation of Windows once I finish college because atm I have wayyyy too much necessary stuff
Sound through headphones not working after sleep
Hi, I have recently updated my realtek audio drivers to the latest version on my acer laptop. But now after my computer comes out of sleep mode, I can't hear anything trough my headphones. When I unplug them, the sound is just fine. I have line in headphones, not USB. The only way to get them...
Sound card problem - headphones work, notebook speakers don't
Hi all, I just bought an old Toshiba A210 laptop and I'm dealing with a couple of (minor) problems. As the title says, I've tried every conceivable control, I can't get any sound from the speakers. No hissing sound, nothing, completely silent. Headphones work fine though. I checked device...
Computer thinks it has no sound card unless headphones plugged in
Unless I have speakers or headphones plugged in, my computer gives me the red "X" over my sound icon in my system tray, and anything that involves sound won't work. This is annoying because I don't always want to listen to sound at work, but I still need to be able to play things that have sound...
Best SteelSeries Siberia uSB sound card settings?
I have disabled Realtek onboard audio in device manager, should i also disable AMD HD audio device..what is it for? I have no other digital devices,just the 2.1 speakers.
SteelSeries USB Siberia Sound Card Problems
Hello... so i bought a pair of Siberia V2's (black version) and later i bought the card itself (black version) so here is the problem since i play a lot of Counter Strike from time to time my left and right channel swap and that's a really big problem and there's this other problem from time...
Sound card controls only headphones, not speakers!
Hi. I have a sound card problem after I installed Windows 7. Previously I had Windows XP and after I replaced OS some days after I noticed something weird - I can control headphones ONLY (volume, balance etc.) but my built in speakers are living completely independent life.:shock: If I`m playing...
