Windows 7: Digital Audio S/PDIF problem
28 Sep 2014   #11
fireberd
Microsoft's listed requirements is 2GB MINIMUM for 64 bit OS.
28 Sep 2014   #12
mihiloff
Windows 7 x64
I still dont know what do you want to say,for me,everything is working,im using a cd for windows 7 ultimate,the same one for last couple of years as i said and everything was working,now everything works also,just this Digital Audio S/PDIF showed up and i dont know to fix it,thats what im saying.
28 Sep 2014   #13
fireberd
I was just pointing out that you are below the MINIMUM requirements that Microsoft has stated. It may work, but how well it works is questionable.
28 Sep 2014   #14
mihiloff
Windows 7 x64
Well,everything im using,works,and it is working properly.
03 Oct 2014   #15
mihiloff
Windows 7 x64
So anyone have some solution or i can lock this topic?
03 Oct 2014   #16
theveterans
Windows 7 Professional x64 SP1
Did you download the drivers I provided from the previous page?
04 Oct 2014   #17
mihiloff
Windows 7 x64
I tried to download from that site,but i dont know why i cant start the download,it just wont start,and when it does start,my download is just so slow(btw i have strong download speed dont know why it is so slow).
04 Oct 2014   #18
jumanji
Windows 7 Home Premium 32 bit
Quote   Quote: Originally Posted by mihiloff View Post
I have almost forgotten all about SPDIF after having hooked up my PC to my TV and amp in the living room years ago. I don't even touch that mini-PC now..
You are obviously using an optical cable one end of which is plugged into your PC.
Where does the other end go? (In my case it is the AV receiver/amp.) And is that equipment set to receive SPDIF input? Check,
04 Oct 2014   #19
mihiloff
Windows 7 x64
@theveterans
Yes i did couple of them,and this is what it says.
04 Oct 2014   #20
mihiloff
Windows 7 x64
So I installed Realtek High Definition Audio Codecs,and this is what i get
Still gettin' no sound from my speakers,and still cant make my speakers as default playback device.
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
Device working but sound doesn't come out Digital Audio S/PDIF
I have a problem with audio, after upgrading to windows 7 home 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed...
How does S/PDIF Digital Audio work?
Hey, I was wondering how the hell does S/PDIF Digital Audio work and how does it remember exactly what % volume it should be on a motherboard? I don't have any speakers, just a keyboard and mouse and I've, reset BIOS, reformatted and reinstalled windows 7 disc and the S/PDIF still remembers what...
Digital Audio (S/PDIF) Making a Digital Sound with Internet Surfing?
Hi, I've recently switched to Digital Audio (S/PDIF) (High Definition Audio Device) using one Toslink cable instead of all the analog wires going from my PC to my receiver. The digital sound is amazing, CD quality from my PC is great. However, I now also receive the digitized sound of...
windows 7 wrongly detected my audio as S/PDIF
My motherboard's has 3 'holes' for audio.(blue,pink,green) But I've no idea why there is an S/PDIF and my speaker doesn't play any sound as I testing. (I've tried to uninstall the hardware and reinstalled again.) Any idea?
Hardware & Devices
