Windows 7: Digital Audio S/PDIF problem
05 Oct 2014   #21
theveterans
Windows 7 Professional x64 SP1
Well, here's another drivers to try:
Realtek High Definition Audio Driver for Microsoft Windows 7 (32-bit, 64-bit) - IdeaPad Z570 - Lenovo Support (US)
That's for a laptop but then again, if the inf file has your hardware ID on the list, it should work without problems. Hopefully this will be the solution or else you need to get a Digital to analog Converter (i.e. external soundcard) with SPDIF input to get sound out of your speakers.
06 Oct 2014   #22
mihiloff
Windows 7 x64
Nothing happend,i dont know what is the problem,really.It was always working fine,i never used that external soundcard.Maybe my soundcard isn't working,how can i check that?
06 Oct 2014   #23
theveterans
The device should say something like Code 10 or Code 43. Can you see if shows any error on Device Manager?
07 Oct 2014   #24
mihiloff
Windows 7 x64
It says
Device status
This device is working properly.
07 Oct 2014   #25
theveterans
Try reinstalling the drivers by making sure to delete the driver software:
15 Oct 2014   #26
mihiloff
Windows 7 x64
Tried still nothing,ill try external soundcard than Ill see what will happen.
15 Oct 2014   #27
theveterans
Anyways, it's still baffling that you can't install realtek drivers even though the soundcard is actually realtek HD audio per hardware ID. It's also astonishing that you can't select speakers as default device despite device manager showing that the device is 100% functioning.
Quote   Quote: Originally Posted by mihiloff View Post
External soundcards tend to be expensive as they're usually sold to audio enthusiasts who are willing to pay ridiculous price to gain a subjectively improved sound. You'll probably be surprised by how much they cost considering that they only convert digital to analog sound. External soundcards are mostly plug-n-play so you won't need to download drivers at all. Just make sure to set the default device to Digital Audio (USB) and plug your speakers to the 3.5mm jack on the soundcard.
Digital Audio S/PDIF problem-capture.jpg
If you want to spend the least amount of money in external sound cards and don't need to get a Hi-Fi USB sound card (more commonly known as DAC by audio enthusiasts), I suggest to buy Syba SD-CM-UAUD USB Stereo Audio Adapter which is the cheapest that I can find. Also, don't get confused with a headphone amp and a USB DAC as headphone amp only amplifies the volume output of the soundcard while a USB DAC is essentially an external sound card.
16 Oct 2014   #28
mihiloff
Windows 7 x64
My brother is a musician,he has external soundcard so I will try his soundcard when he gets it from his friend.I hope that it will work.I cant see the other solution,maybe my soundcard isnt dead,maybe it is just a green conector for speakers that died? Could that be a problem,what do you think?
16 Oct 2014   #29
theveterans
I'm guessing that the amplifier on the built-in sound card is broken which is probably why you can't set speakers as the default audio. If the DAC chip is the one that broke, Windows would've shown a code 43 error or code 10. I've never experienced a dying onboard soundcard so I have no clue.
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
Device working but sound doesn't come out Digital Audio S/PDIF
I have a problem with audio, after upgrading to windows 7 home 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed...
How does S/PDIF Digital Audio work?
Hey, I was wondering how the hell does S/PDIF Digital Audio work and how does it remember exactly what % volume it should be on a motherboard? I don't have any speakers, just a keyboard and mouse and I've, reset BIOS, reformatted and reinstalled windows 7 disc and the S/PDIF still remembers what...
Digital Audio (S/PDIF) Making a Digital Sound with Internet Surfing?
Hi, I've recently switched to Digital Audio (S/PDIF) (High Definition Audio Device) using one Toslink cable instead of all the analog wires going from my PC to my receiver. The digital sound is amazing, CD quality from my PC is great. However, I now also receive the digitized sound of...
windows 7 wrongly detected my audio as S/PDIF
My motherboard's has 3 'holes' for audio.(blue,pink,green) But I've no idea why there is an S/PDIF and my speaker doesn't play any sound as I testing. (I've tried to uninstall the hardware and reinstalled again.) Any idea?
Hardware & Devices
