Digital Audio S/PDIF problem
  1. Posts : 8,135
    Microsoft's listed requirements is 2GB MINIMUM for 64 bit OS.
  2. Posts : 16
    Windows 7 x64
       #12
    I still dont know what do you want to say,for me,everything is working,im using a cd for windows 7 ultimate,the same one for last couple of years as i said and everything was working,now everything works also,just this Digital Audio S/PDIF showed up and i dont know to fix it,thats what im saying.
  3. Posts : 8,135
    I was just pointing out that you are below the MINIMUM requirements that Microsoft has stated. It may work, but how well it works is questionable.
  4. Posts : 16
    Windows 7 x64
       #14
    Well,everything im using,works,and it is working properly.
  5. Posts : 16
    Windows 7 x64
       #15
    So anyone have some solution or i can lock this topic?
  6. Posts : 562
    Windows 7 Professional x64 SP1
       #16
    Did you download the drivers I provided from the previous page?
  7. Posts : 16
    Windows 7 x64
       #17
    I tried to download from that site,but i dont know why i cant start the download,it just wont start,and when it does start,my download is just so slow(btw i have strong download speed dont know why it is so slow).
  8. Posts : 7,055
    Windows 7 Home Premium 32 bit
       #18
    I have almost forgotten all about SPDIF after having hooked up my PC to my TV and amp in the living room years ago. I don't even touch that mini-PC now..
    You are obviously using an optical cable one end of which is plugged into your PC.
    Where does the other end go? (In my case it is the AV receiver/amp.) And is that equipment set to receive SPDIF input? Check,
  9. Posts : 16
    Windows 7 x64
       #19
    @theveterans
    Yes i did couple of them,and this is what it says.
  10. Posts : 16
    Windows 7 x64
       #20
    So I installed Realtek High Definition Audio Codecs,and this is what i get
    Still gettin' no sound from my speakers,and still cant make my speakers as default playback device.
