Windows 7: Digital Audio S/PDIF problem
27 Sep 2014   #1
mihiloff
Windows 7 x64
So guys,I havent been turning on my pc(using win 7) for like a month,when i did it was saying Digital Audio S/PDIF and no sound was going nor through speakers nor through headphones.Before that everything was working fine.So,since i had some viruses on it i reinstalled win,formated both particions,but still that Digital Audio S/PDIF stayed there,in the device menager it says High Definition Audio Device,and it has 2 of them,i tried through device menager to update it but it says that the best driver is already intalled.I searched threads here,tried some downloads but nothing is changed.Since im a musician a little,gamer a little and pc user i really need to fix this,can someone help me?
Here are the specs
28 Sep 2014   #2
theveterans
Windows 7 Professional x64 SP1
Headphones and Loudspeakers only accept analog audio. You need a Digital to Analog converter, i.e. a sound card, to decode the digital audio and convert it to analog signal which is then amplified by the amplifier and then transferred to headphones and loudspeakers which translate those signals to sound waves.
Try setting the "speakers" as the default audio device by right clicking the sound icon on the system tray -> playback devices -> click on speakers -> set default audio device.
28 Sep 2014   #3
mihiloff
Windows 7 x64
Hey theveterans,thanks on your answer.
I have already tried that but when i try to do that this is what happends
I cant even do it,maybe my sound card isn't working? But how? It worked,PC wasn't turned on,how could it just die like that?
28 Sep 2014   #4
fireberd
Disable the S/PDIF and then see if you can make the Speakers the default playback device.
This is an older motherboard and I couldn't find any Win 7 drivers for it, although it may have Vista drivers which will work. As you only have "High Definition Audio Device" that suggests that the generic, basic function, Windows installed sound driver and not the actual hardware sound driver.
28 Sep 2014   #5
mihiloff
Windows 7 x64
Hey fireberd,thank you for your response,
Tried that too,i disable Digital Audio S/PDIF,but still i couldnt Set as default my speakers nor headphones,plus,if i disable Digital Audio S/PDIF i get this
28 Sep 2014   #6
theveterans
Is the 3.5mm plug connected to the "green color" slot on the rear panel of your desktop?
If it's connected to it, you should be able to set the speakers as the default device.
28 Sep 2014   #7
mihiloff
Windows 7 x64
Yes,yes it is.My speakers are working,i can adjust volume and bass,i can turn them on and off.If i play something on my pc,Digital Audio S/PDIF is working it shows like the green bar is going up and down but nothing comes out from the speakers,i disabled Digital Audio S/PDIF and still nothing.Some of my friends say that it is about the drivers,i tried to download latest Realtek i couldnt even launch them,tried some for High Definition Audio,couldnt install them,i dont know what to do anymore,im not really a pc dude,i know to crack games and some little stuff,but i was never this "deep",so Im asking someone to help me please.
28 Sep 2014   #8
fireberd
The amount of memory may or may not be an issue. I see you only have 1.5GB of RAM but have Windows 7 64 bit OS. The main reason for 64 bit OS is that it can address more than 4GB of RAM. In fact the 64 bit OS requires more system memory than a 32 bit, not leaving you much RAM. Microsoft system requirements are MINIMUM of 2GB for 64 bit OS.
28 Sep 2014   #9
theveterans
Alright.
Go to device manager -> Sound, video and game controllers -> right click on the High Definition Audio Device (if 2 shows up, just do the same for both) -> properties -> details -> on drop down, select Hardware ID's and copy and paste those here. I'll see if it's actually realtek or a different manufacturer.
You can also try those on a search engine to see which manufacturer and even find the right drivers for that device.
If it's realtek, try installing the drivers from the realtek website here: http://www.realtek.com.tw/DOWNLOADS/...own=false#High Definition Audio Codecs
28 Sep 2014   #10
mihiloff
Windows 7 x64
Okay,
@theveterans thoose are the Hardwer ID's
HDAUDIO\FUNC_01&VEN_10EC&DEV_0862&SUBSYS_1565C601&REV_1000
HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1001
It showed 2 of them so i did for both.
Fireberd,I am not sure what do you want to say,but im using x64 since when i am using windows 7 which is couple of years now,everything was always working,even when i had 1GB of RAM,i put 1 more in another slot from 512 just so i can play competitive one game since i had some iching problems.
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
Device working but sound doesn't come out Digital Audio S/PDIF
I have a problem with audio, after upgrading to windows 7 home 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed...
How does S/PDIF Digital Audio work?
Hey, I was wondering how the hell does S/PDIF Digital Audio work and how does it remember exactly what % volume it should be on a motherboard? I don't have any speakers, just a keyboard and mouse and I've, reset BIOS, reformatted and reinstalled windows 7 disc and the S/PDIF still remembers what...
Digital Audio (S/PDIF) Making a Digital Sound with Internet Surfing?
Hi, I've recently switched to Digital Audio (S/PDIF) (High Definition Audio Device) using one Toslink cable instead of all the analog wires going from my PC to my receiver. The digital sound is amazing, CD quality from my PC is great. However, I now also receive the digitized sound of...
windows 7 wrongly detected my audio as S/PDIF
My motherboard's has 3 'holes' for audio.(blue,pink,green) But I've no idea why there is an S/PDIF and my speaker doesn't play any sound as I testing. (I've tried to uninstall the hardware and reinstalled again.) Any idea?
Hardware & Devices
