Windows 7: sounds problem after Changing from 32bit to 64 bit
03 Oct 2014   #1
tomo21
Hi All,
new here so hope i dont piss anyone off by posting in the wrong place etc,
Anyway i was using 32bit and decided to go for 64 bit
so on installing Win7(64bit) my little sounds bubble in bottom corner has no gained a little red X next to it and says:
Quote:
No Audio Output Device Is Installed
i have logitech X-530 speakers that worked fine on 32bit
i also had a realtek software installed on 32bit but dont have a clue which one
thanks
03 Oct 2014   #2
BugMeister
you need to get 64-bit drivers
nip over to Realtek's site and look for them
before you install them make sure that you remove any previous drivers
and run something like CCleaner's Registry cleaner to get rid of any "stubs"
Problem with Changing System Sounds and Screensavers
Hi, When I try to change the screensaver, a box pops up saying that rundll32.exe can't be found. When I try to change the system sounds, a box pops up saying that control.exe can't be found. I looked through my folders and I did find them. I might have a virus because other problems are also...
Customization
[Win 7 32bit] Weird hangups usually when playing sounds
Hi, Ok so the problem is as follows. Sometimes when I play sounds on computer (can be msn,video/audio, software, youtube) the computer slowly creeps towards a freeze. Sometimes the sound starts crackling and sometimes the sound keeps playing uninterrupted (say I have a song playing, it might...
No Windows Sounds, but regular sounds play fine
Ok so I have a simple, but annoying problem. I have no Windows Sound Events like the login sound, the logout sound, and when the battery is low. Every other sound like playing music and running YouTube videos work fine. Even when I turn on my laptop I hear the whole computer startup sound, but I...
I here broken sounds. How do i fix this problem?
Hello buddies! Today when i playing Audio and video files some times every media files i here broken sounds (Windows Media player in windows 7). Then i play another files using windows media player then problem again happen. After that i run another files using Vlc media player. Problem still...
Changing Bit Size From 64bit To 32bit .
I Need To change my windows 7 ultimate 64-bit to 32-bit Widnows 7. Will it be easy to change my OS. My configuration is 3GB ram with Pentium(R) Dual-Core Cpu T400 @ 2.14 GHz . please Suggest Your opinion as fast as possible .
Installation & Setup
Sounds - Allow or Prevent Changing
How to Allow or Prevent Changing Sounds in Windows 7 and Windows 8 This will show you how to allow or prevent all or specific users on the computer to add, remove, or change the current system sound scheme in Windows 7 and Windows 8. You must be logged in as a administrator to be able to do...
Tutorials
