Windows 7: Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio
07 Oct 2014   #1
cees09
Hi, hope you guys can help/guide me out.
So I receive a gift a couple of months ago, but did not have the chance to test it until now.
I have a set of audio speakers+sub-woofer, if you take a look at the pics (specially the back.jpg) the speakers are connected through a RCA cable, and where says input its a 3.5mm cable that goes into the computer (speakers output)
Now when I connected them to the PC, the sub-woofer and right speakers works fine, but the left is not producing audio at all. I find out that both speakers are working fine if I connected them in the red output/R, seems the left one is not working. At first I thought it was config of my PC I did download the latest drivers from Realtek Website, I tried the ones that comes from the DVD/Motherboard (ASROCK H81M-HDS) and same issue. I tried multiple settings from the audio devices (5.1 surround, quadraphonic, stereo) but no success.
Finally what I did is that I connected the system to my Galaxy S3 smartphone and another audio system as well and I have the same issue, no audio coming from the output Left/White, Subwoofer is working fine, and output/Red(Right) is working fine. I'm not sure if its due to the fact that system receives the signal from a 3.5mm cable and then has to send it through 3 outputs (L/R RCA speakers and the subwoofer)
What I'm trying to find out is, if this something related to the audio system itself, or does the PC and S3 need a configuration?
In case is something related (hardware) of the audio system, could it be repairable?
thanks in advance!
Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio-completeset.jpg   Audio 2.1 Speakers+Subwoofer, one speaker not outputting audio-back.jpg
07 Oct 2014   #2
fireberd
As the speakers do the same thing on two different systems it says there is a problem with the speaker system. I see RCA connectors on the rear for the two speakers. Switch the connections (connect the right speaker to the Left jack and the left speaker to the right jack) and see if it follows the speaker or if its the Left output from the speaker base. That will isolate where the problem is. If its the speaker base unit, the problem could be the cable that connects to the PC or it could be an internal amplifier problem. However, in either case if the speaker system is still under warranty, contact the manufacturer for warranty assistance.
In most cases these are not made to be repaired, but I see screws holding the back on, the base unit, and you may be able to get into the electronics. However, without a schematic you are probably not going to find any problems.
Need some help with audio/speaker systems
Ok, so currently I have a old sony analog receiver with 8 large analog speakers. They sound nice and all, but with the newer ps4 and other hardware I am getting, I would love to upgrade my speaker system on the cheap. As In, not $300 or more. (I am getting married after all lol) The ps4 only has an...
Chillout Room
VIA HD Audio 2.1 or subwoofer cutoff frequency
Greetings! I have an issue with my VIA HD audio. I only need to listen stereo music in 2.1 channels. My datas: Package version: 11.4.00.30 Codec Version: VT2021 Driver Version: 6.0.11.0400 I only be able to set 2 channels, 4 channels, 6 channels (obviously 5.1), and 8 channels.
No Speaker audio - Headphone audio okay
My wife has a dual boot operation using Windows 7 and Ubuntu 14.04. Here is the situation: There is no audio in Windows 7 through the speakers. The audio is okay in Windows 7 through the headset. The audio is okay in Ubuntu speakers and headset. I can't determine what happened to the audio...
Desktop only outputting Left audio. Right does not come out.(Speakers)
Sup! An uncle of mine currently has an old dekstop . He purchased a couple of Technomaster speakers with subwoofer (2.1 Sound System) a couple of weeks ago. He sent the computer to repair at one moment, because the Mobo's LAN card somewhat died (It wasn't detecting the plugged in cable), and was...
Subwoofer doesn't work windows 7, realtec audio.
I'm trying to config my sound system and sub out only works in "test" actually now it doesn't work at all! the rest of my speakers work fine for the most part. I have tried everything I can think of and this is really getting to me, I use my computer for movies, netflix, music quite often. I'm...
Motherboard might be defective: audio through one speaker?
Hi all, I have a slight problem with my audio and I decided to come here before racing to get an RMA from Newegg. Anyways, the rear audio jack on my new build only feeds sound through the right speaker and my subwoofer, but the left speaker is completely silent. I've already tried a set of...
