Windows 7: Using both front panel audio and back panel: solutions
12 Oct 2014   #11
pintree3
Windows 7 Home Premium 64
I assumed that, HDA, meaning high_Definition Audio Controller, 'controlled' the HD sound, that is any hd sound and not necessarily the sound card (onboard or added). But it seems I am wrong here with this assumption. OK then if this is indeed what controls my onborad soundcard it would make sense for me to disable it, since my sound card does have something to attach to the front panel. (Wjat it says in the manual is: 'Front Panel audio header' defined as : " 9-pin Intel AC'97 / HDA front-panel which supports audio jack detection & audio headphone selection for Analog Out on the Audio Center."
BTW my audio card also has an ''S/PDIF Out Header'' which ''connects to the supported graphics card with HDMI" I was wondering if I should do so?--connect it to my sound card since it also has an 'S/PDIF Out Port'--not knowing the difference between the 2.
Thanks again to all of you
12 Oct 2014   #12
Berton
I would try disabling the HDA Controller then install the Add-in card and its software/drivers and use the header connection. Seems to me S/PDIF would not be needed for using audio in a computer.
S/PDIF - Wikipedia, the free encyclopedia
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
No Audio from front or back panel jacks.
I have this motherboard. and get no audio when I plug in headphones in the front or back ports. I'm running win 7 so there aren't compatible drivers available on asus site, I tried downloading the vista x64 and installing them in compatibility mode but the device manager shows "High...
Need help with Front Panel HD Audio
I have had this problem for months and I have never been able to solve it. Bios is set for HD Audio. When I connect the front panel hd audio plug from my Lian-Li A77 case into the Asus Rampage II Extreme Supreme FX mini sound card the system will boot up normally. Then when I plug in the...
help me with the front audio panel :(
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver,...
