Windows 7: Using both front panel audio and back panel: solutions
08 Oct 2014   #1
pintree3
Windows 7 Home Premium 64
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better.
I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium 64bit.
I asked ASUS tech if I can use both the front panel & back panel at the same time for use of my headset (headphones and mic therefore headphone jack and mic jack.) They said NO that I had to choose one or the other, not both, and, that this has nothing to do with the sound card or MB but rather is a Windows thing. I assume this info is correct. Is it? If not please advise me as how to be able to use both.
On the assumption that it is correct, that I must make a choice an idea popped up.
My speakers are 'Cyber Acoustics CA-5402'. They have a control pod whereby on this control pod I could add my headphones whereby all speaker sounds are cut off automatically. Unfortunately this control pod which also controls the volume of the speakers no longer has control of the volume when the headphones are on and therefore volume must be controlled via Windows.
My idea. Can the Xonar, or rather Windows along with it, be set up so as to use only the front panel for the mic but NOT for the headphones?
OR
Since the control pod also has and 'aux in' (unfortunately not 'aux out') maybe this could be hacked somehow.
OR
Since I actually have 2 control pods, of which only one can be attached (to the woofer which has all the other cables attached to it) would it be possible to somehow make this 2nd control pod (attached for ex. with a splitter and then hacked somehow) to be used for the mic?
Or should I be going to an 'electronics website for such a questions?
Thanks ye all :-)
09 Oct 2014   #2
fireberd
Whether you can use both, depends on the sound card software, not Windows. You should be able to use the front for mic and the GREEN speaker jack on the back for the headphones. However, why would you want to do that? If you plug the headphones into the rear speaker jack, you have to unplug the speakers from the PC to do this.
Normal operation is to use the front panel for the headphones (and mic) and when you plug in the headphones it mutes the output to the speakers. On some sound card control software (for example RealTek) there are options to either mute the speakers when the headset is connected or not mute the speakers and have both headset and speaker sound.
You have to use the designated Mic input, as a PC mic requires 5VDC for operation. Other than the mic input, others do not have 5VDC.
On the front panel connections. Your front panel audio connection must be to the ASUS Xonar and not to the motherboard sound connection. Since you have a separate sound card, your motherboard sound should be disabled in the BIOS so it does not conflict with the Xonar. In addition, you can only have one default audio playback device (e.g. Xonar OR motherboard sound but not both).
09 Oct 2014   #3
pintree3
Hey fireberd it's you again :-) Always nice to read your opinions/suggestions/help.
Yes, I agree with you--logic would dictate that, would it not. I mean that is what I had back in the XP days. That is that both should be able to be used.
When I 1st bought this PC with the onboard sound card I was told by the techs who built my PC that I had a choice--one or the other and not both. So this was not the first time I heard this. Unless they actually meant I can not use both at the same time--which would make perfect sense but I doubt this is what they meant. Hence now with a new sound card added I am told the same thing. I am now, to make this story as short as possible, in the position where I have been told not twice but numerous times but various people about such a thing and always it being a Windows thing and not hardware thing. Is it possible that in all cases they had assumed I meant both at the same time? I guess anything is possible.
The thing is that now as before the front panel could never be used since it is set up for the back panel. I guess yes I should go to the BIOS and disable the motherboard sound card (if I am not mistaken my video card has some audio as well--HDMI: I guess having to do with that cable)
09 Oct 2014   #4
Berton
One thing that has always been present in audio devices is that plugging into a different socket disables the other one. When I want both speakers and headphones I use a Y-cable or splitter in the back socket, seems to be more powerful than the front.
3.5mm Headphone Splitter
Headphone Cable Splitter (3.5mm) Stereo Male to 2 Female Audio, 6in
09 Oct 2014   #5
fireberd
The Windows restriction is you can only have one default audio playback device. e.g. either the ASUS Xonar or you on board audio, but not both. But, since you have the Xonar, as I noted disable the on-board in the BIOS. That eliminates one potential conflict.
The front panel connections are most likely connected to the front panel audio jack on the motherboard. In order to use the front panel jacks that must be plugged into the Xonar card. Many cases have both "HD Audio" and "AC97" connectors for the front panel. The HD Audio is the one to use as it has jack sensing (and what the Xonar DG front panel header (connection) is set up for. Assuming there is no problem with the front panel jacks on your case this will allow you to use both the headset and mic jacks.
From the Xonar DG specs:
Quote:
Front-Panel Header:
Supports headphone jack-detection, automatically switch audio output from back-panel to front
I don't know what Xonar has for a control panel, but it is most likely found in the Control Panel/Hardware and Sound section (that is where the RealTek HD Audio Manager is located).
10 Oct 2014   #6
pintree3
I hate opening my PC case. Every time I go in, having so much hardware and corresponding cables and wires something goes wrong since there is so little space to move around. Usually some wire gets loosened, and the PC, due to the protective measures of the power supply, won't start. I replaced 1/2 my cables to avoid this looseness that keeps on happening. Anyhow, yup I guess I will open my case and I will go into my BIOS. Thanks for all of your help
10 Oct 2014   #7
Berton
Don't have to open the case to access the BIOS, just press a key when prompted at the bootup [while that prompt is still showing on the screen].
10 Oct 2014   #8
pintree3
No, no, no :-) I did not mean to imply I needed to open my case to get into my BIOS.
I meant I will open my case to check my wiring/cabling for my Xonar and onboard sound cards and then (with case closed) boot in and get into my BIOS--2 separate actions
12 Oct 2014   #9
pintree3
Hi again. OK attached is a photo of the only place on my BIOS where I see references to sound. I don't understand it or rather I don't get it: There is no mention of my Xonar or anything else really as you can see. What is there is, "Front Panel type -- HD Audio" and nothing else, nothing about the back panel, nothing about my on-board sound card or my Xonar. So in theory at least, there is nothing for me to do here in my BIOS concerning my sound--nothing to enable or disable.
Since this is the "Onboard device configuration" perhaps the BIOS is saying 'this is the MB itself anything else attached to it I don't know about.'' OK then what of the back panel'? and where would everything else be--heck I don't even see my video card either
Using both front panel audio and back panel: solutions-myasusbios_07advancedonboard3.jpg
12 Oct 2014   #10
Berton
That's true. The only thing I've seen automatic on a number of different computers is disabling the built-in video adapter when an Add-in Video card is added.
As for your HDA Controller setting it looks to me like the only choice is for Enabled or set to Disabled when using an Add-in sound card. But that changes the front-panel choice so an Add-in card would need to support the front panel sockets.
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
No Audio from front or back panel jacks.
I have this motherboard. and get no audio when I plug in headphones in the front or back ports. I'm running win 7 so there aren't compatible drivers available on asus site, I tried downloading the vista x64 and installing them in compatibility mode but the device manager shows "High...
Need help with Front Panel HD Audio
I have had this problem for months and I have never been able to solve it. Bios is set for HD Audio. When I connect the front panel hd audio plug from my Lian-Li A77 case into the Asus Rampage II Extreme Supreme FX mini sound card the system will boot up normally. Then when I plug in the...
help me with the front audio panel :(
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver,...
