Windows 7: Sound Blaster Audigy Rx Microphone Not Working
11 Oct 2014   #11
TopNotch115
Windows Seven
Power off the PC and then reseat (unplug then plug back in) the SoundBlaster Card. And/or try a different slot.
Did that, and nothing changed.
12 Oct 2014   #12
fireberd
With what has been done, either the SoundBlaster has a problem or possibly driver. Maybe if you completely uninstalled all the SoundBlaster drivers and software and started over it MAY work.
13 Oct 2014   #13
TopNotch115
Windows Seven
Alright, O have done that and now my microphone works! Thank you so much for your help!
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Sound Blaster audigy 2 Value malfunction
Hi. First of all, i would like to say, that i am from central europe, non-english speaking country so be tolerant to my language mistakes, please. Thanks. I didn't find here, or anywhere else, someone with similar problem, so that im asking you for help. Some time ago my sound card just stop...
Sound Blaster Audigy 2 isn't nearly as loud in Win 7
my sound card is the SB audigy 2. Back in XP the drivers usually worked fine and produced the right 'loudness' of sound. however in windows 7 the drivers that were automatically installed upon the OS installation do NOT play audio at the regular decibel levels. I tried going to downloading the...
seems a lot of people are having issues with the sound blaster audigy cards, me included. Im dual bootin windows 7 and XP, on windows XP my sound card works and everything, when i boot in windows 7, dosnt even detect my card. I have the driver i need to get it to work, its just not detecting it to...
my sound card is the SB audigy 2 zs platinum. Back in XP the drivers usually worked fine and produced the right 'loudness' of sound. in vista i had to try a few different sets of drivers but got it working correct. however in windows 7 the drivers that were automatically installed upon the OS...
Creative Sound Blaster Audigy LS Not Working
Hello, I've installed Windows 7 on my desktop with dual boot to Vista. Everything's been working fine but I haven't been able to properly setup my sound-card to function properly. As of now, I currently have no sound and I've been through many different drivers from the Creative website. I've...
