Sound crackling/popping
Page 2 of 2 FirstFirst 12
  1. Posts : 1,449
    Windows 7 ultimate 64-bit
    Another thing to consider trying is; completely uninstalling the sound card listed in system devices in the device manager; rebooting; letting windows re-detect and reinstall the drivers for the sound card; then go to the sound card manufacturers site and see if there are any updated drivers for your card and download and install them and see if that resolves the issue. Sometimes i believe what can happen is for one reason or another; something within windows will "Corrupt" the audio drivers which can possibly cause the issue you are having. Give this a shot and report back if it doesnt and we can try and go from there.
  2. Posts : 9
    Windows 8.1 64bit
       #12
    I have tried both, deleting realtek drivers and let windows download them back, and also manually download from realtek website.
    Here is two sound recordings. Using speakers, not headset and problem still exist.
    In this video i turn volume completely off and then back on
    https://www.youtube.com/watch?v=6d2p...ature=youtu.be
    In this video I only change volume, but i keep it on and wont turn off at all. Using some low sound and bass turned to low.
    https://www.youtube.com/watch?v=0_BH...ature=youtu.be
    It happens only when I am adjusting volume or start/stop video
  3. Posts : 11,424
    Windows 7 Ultimate 64
    Try connecting your front panel audio and plugging into that with the headphones.
  4. Posts : 9
    Windows 8.1 64bit
       #14
    Connected front panel audio to Mobo, exactly same thing there.
  5. Posts : 11,424
       #15
    OK well I'm out of suggestions unfortunately. Unless there's a resource or virus issue. Which is highly unlikely as you said this moved from the previous machine to this new rig with only those two components transferred....so I think it's one of those two components which is causing the issue.
  6. Posts : 9
    Windows 8.1 64bit
       #16
    Strange, I tried my old computer (bought some cheap GPU and RAM) and it still has same crackling problem, and my new built system has it also? Also bought new GPU to this new computer, only RAM exists from old computer, but that shouldnt be the problem because got new ram for old computer and its still crackling.
    What the hell.
    What is that CPU throttling? how I can disable it?
  7. Posts : 9
    Windows 8.1 64bit
       #17
    Ok made new test with latencymon when I was playing and using mumble
    CONCLUSION
    ____________________________________________________________________________________________________ _____
    Your system seems to have difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
    LatencyMon has been analyzing your system for 0:06:18 (h:mm:ss) on all processors.
    SYSTEM INFORMATION
    Computer name: COMPU
    OS version: Windows 8 , 6.2, build: 9200 (x64)
    Hardware: ASRock, H97M Pro4
    CPU: GenuineIntel Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
    Logical processors: 4
    Processor groups: 1
    RAM: 8127 MB total
    CPU SPEED
    Reported CPU speed: 3299,0 MHz
    Measured CPU speed: 3454,0 MHz (approx.)
    Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
    MEASURED INTERRUPT TO USER PROCESS LATENCIES
    The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
    Highest measured interrupt to process latency (µs): 1383,111268
    Average measured interrupt to process latency (µs): 3,409666
    Highest measured interrupt to DPC latency (µs): 1366,970831
    Average measured interrupt to DPC latency (µs): 0,857943
    REPORTED ISRs
    Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
    Highest ISR routine execution time (µs): 153,836617
    Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
    Highest reported total ISR routine time (%): 0,138836
    Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
    Total time spent in ISRs (%) 0,188672
    ISR count (execution time <250 µs): 397490
    ISR count (execution time 250-500 µs): 0
    ISR count (execution time 500-999 µs): 0
    ISR count (execution time 1000-1999 µs): 0
    ISR count (execution time 2000-3999 µs): 0
    ISR count (execution time >=4000 µs): 0
    REPORTED DPCs
    DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
    Highest DPC routine execution time (µs): 1405,975144
    Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 340.43 , NVIDIA Corporation
    Highest reported total DPC routine time (%): 0,081605
    Driver with highest DPC total execution time: Wdf01000.sys - Suorituksenaikainen ydintilaohjainkehys, Microsoft Corporation
    Total time spent in DPCs (%) 0,307362
    DPC count (execution time <250 µs): 1840910
    DPC count (execution time 250-500 µs): 0
    DPC count (execution time 500-999 µs): 61
    DPC count (execution time 1000-1999 µs): 4
    DPC count (execution time 2000-3999 µs): 0
    DPC count (execution time >=4000 µs): 0
    REPORTED HARD PAGEFAULTS
    Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
    NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
    Process with highest pagefault count: arma3.exe
    Total number of hard pagefaults 263
    Hard pagefault count of hardest hit process: 84
    Highest hard pagefault resolution time (µs): 1509260,805396
    Total time spent in hard pagefaults (%): 0,440081
    Number of processes hit: 14
    PER CPU DATA
    CPU 0 Interrupt cycle time (s): 12,153733
    CPU 0 ISR highest execution time (µs): 153,836617
    CPU 0 ISR total execution time (s): 2,854715
    CPU 0 ISR count: 397490
    CPU 0 DPC highest execution time (µs): 1405,975144
    CPU 0 DPC total execution time (s): 4,020926
    CPU 0 DPC count: 1603952
    CPU 1 Interrupt cycle time (s): 3,878882
    CPU 1 ISR highest execution time (µs): 0,0
    CPU 1 ISR total execution time (s): 0,0
    CPU 1 ISR count: 0
    CPU 1 DPC highest execution time (µs): 185,279782
    CPU 1 DPC total execution time (s): 0,407372
    CPU 1 DPC count: 138305
    CPU 2 Interrupt cycle time (s): 3,603882
    CPU 2 ISR highest execution time (µs): 0,0
    CPU 2 ISR total execution time (s): 0,0
    CPU 2 ISR count: 0
    CPU 2 DPC highest execution time (µs): 85,354047
    CPU 2 DPC total execution time (s): 0,113766
    CPU 2 DPC count: 51998
    CPU 3 Interrupt cycle time (s): 4,136180
    CPU 3 ISR highest execution time (µs): 0,0
    CPU 3 ISR total execution time (s): 0,0
    CPU 3 ISR count: 0
    CPU 3 DPC highest execution time (µs): 87,189148
    CPU 3 DPC total execution time (s): 0,108514
    CPU 3 DPC count: 46720
