Windows 7: Headphones plugged to speakers,extremely low sound.
29 Oct 2014   #1
ggmagos
windows 7 64
I have plugged the headphones to my speakers but the sound is extremely low.
I have tried different headphones it is the same low sound.
These headphones in other devices work perfect.
The speakers also work perfect.What is the problem?Any suggestions?
I have a desktop
Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
CPU:Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
GPU:AMD Radeon HD 6700 Series
RAM:4.1 GB
Sound Card:AMD High Definition Audio Device
29 Oct 2014   #2
fireberd
Are you plugging in the headset to a "headset" jack on the speakers? More on exactly how you are doing it.
Second, AMD High Definition Audio Device is NOT your PC's sound device. The AMD is for HDMI audio.
Your PC sound card would be something such as "RealTek", "Conexant" or similar.
Filling in the "My System Specs" helps us to try and help you.
29 Oct 2014   #3
MourningStar
check your computer's volume levels on the sounds mixing console. Also, see if there is a volume knob on the speakers somewhere.
29 Oct 2014   #4
ggmagos
windows 7 64
My computer's volume levels on the sounds mixing console are at 100% everything maxed out.
When I unplug the headphones speakers work fine.Also my headphones have not a knob.
I cannot find nothing except "AMD High Definition Audio Device "when looking for a sound card,device etc on control panel.
The headphones are plugged in the headset jack of my speakers.Thanks again.
29 Oct 2014   #5
fireberd
If you are plugging into some type of jack on the speakers, the volume level is controlled by the speaker system.
Don't you have a headphone jack on the PC's case?
Two sceenshots to post, that will help us understand what you have. First is the Sound Panel, Playback Section and the Device Manager, Sound Section.
Here are screenshots of my Sound Panel/Playback Section and my Device Manager Sound section, for examples. (Ignore the Tranzport entries. They are used in my recording studio only).
Headphones plugged to speakers,extremely low sound.-device-manager-capture.jpg
29 Oct 2014   #6
ggmagos
windows 7 64
The speakers are plugged at the pc tower, and the headphones are plugged at the speakers.
Yes the volume depends from the speakers,but to hear the faintest sound I must turn the speakers up to 100%.
At the 0-70% volume (aproximately) I cannot hear anything from my headphones.If I plug out at 70% volume my headphones then the sound from the speakers will wake up my neighbors.
29 Oct 2014   #7
MourningStar
Quote   Quote: Originally Posted by ggmagos View Post
The speakers are plugged at the pc tower, ...
my tower has a headphone jack. Does yours?
29 Oct 2014   #8
ggmagos
windows 7 64
Quote   Quote: Originally Posted by MourningStar View Post
It has six sockets.
Line in
Line out (where the speakers are plugged)
Mic
and
side,rear,bass.
If I plug my headphones directly to the tower I cannot turn up or down the volume.
Also sometimes I need the speakers sometimes the headphones.
30 Oct 2014   #9
fireberd
That is the audio I/O on the REAR of the motherboard.
Most cases (all that I've seen) have headphone and microphone jacks on the FRONT of the case (and a cable that connects to the front panel I/O connection on the motherboard. That is the usual way of connecting headphones. You then control the volume level with the PC's (RealTek) volume control.
Connecting to a jack on the speakers and you are limited to whatever sound level the speakers output, and in this case, possibly a defective headphone output.
30 Oct 2014   #10
ggmagos
windows 7 64
Ok I think that it is solved.You are right about the two jacks in front.I never used them ,never
even ask why they are there.
The headphones are working perfect at the front jack.
Thank you very much for your responces and the time you consumed.Much appreciated.
No speakers or headphones are plugged in - Windows 7 Sound Problem
Hi All, First time poster and only limited self taught knowledge. Any help is greatly appreciated as have spent many hours over the past few days trying to get sound working on my PC. A life without gaming is getting me down! I have searched hundreds of forum posts but can't seem to resolve...
no speakers or headphones are plugged in
OMG!!! I just installed windows 7 and I cant hear nothing, I have this problem "no speakers or headphones are plugged in" I tried 1000000 type of drivers, and nothing I wonder what is the problem??? I never had this probleem with my old vista :mad::mad::devil: Help???:huh:
No Speakers or headphones are plugged in
Hi iv had this problem for about a month now every time i want to use my sound it just says 'No Speakers or headphones are plugged in' I have tried everything - system restore - plug my headphones in but it does nothing - uninstalling it/ re installing it - keeping it up to date and i tried...
Computer plays sound on main speakers while headphones are plugged in?
Hi! I'm not very good with computers so I need some help with this. When I plug in my head phones my computer does not register them and keeps playing music on the main speakers, I have checked the Sound in the controlpanel but only the main speakers are listed there. I have an Acer Aspire...
General Discussion
Speakers and headphones not plugged in... even though they are
I have a HP Pavilion p6267. For some reason, I have no sound coming out of my stereo speakers or headphones (rear panel and front panel respectively). I have uninstalled and reinstalled the Realtek Audio Driver, downloaded the new update for the driver (which supposedly fixes an HDMI issue),...
No speakers or headphones are plugged in. PLEASE HELP!
I recently took my computer to get a new graphics card GeForce GT 240 and I came back plugged in everything and my speakers didn't work. It worked before I got my new graphics card, Please help this is extremely annoying, I've tried so many other ways.:cry::cry::cry::cry::cry:
