Windows 7: No Sound even with External Sound USB
30 Oct 2014   #1
Kaone
Windows 7 Home 64 bit
A friend of mine has a PC that won't produce any sound. An IT professional has had a quick (1 hr) look so it's unlikely to be an incorrect setting. I suggested trying an external USB sound device but apparently even that doesn't produce any sound.
I'd welcome any suggestions as to what or where the problem might be. Thanks
30 Oct 2014   #2
fireberd
Specs on the PC is needed. Can't really comment without that.
31 Oct 2014   #3
Kaone
I'm afraid it's not my pc so I don't know the exact spec.
I suppose what I'm asking is whether there can be a fault which could only be cured with major surgery (eg - new motherboard) or whether it's worth continuing to check settings and play with the USB sound card.
31 Oct 2014   #4
fireberd
I still cannot make an honest recommendation.
31 Oct 2014   #5
Kaone
Hi Fireberd,
I understand, but it would be very useful just to have your views on whether it's worth spending more time on this problem or if it's best just to accept the lack of sound and wait until the pc has to be replaced sometime in the future.
31 Oct 2014   #6
fireberd
As I'm a tech, I would delve further into it and find out what the problem is.
No sound from external speakers
Googling this subject reveals thousands upon thousands of similar problems, but I haven't been able to get my speaker sound back - they were fine 12 hours ago. I use some simple external USB stereo speakers with my Asus laptop. It has Realtek sound, and I also bought a Xonar U7, through which I...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
No digital sound out of external sound system
I have a GA-EX58-UD3R Rev 1.6 mobo in a PC connected to a Samsung PS63C7000 3D TV via HDMI and by Stereo Analogue, Coax and Optical to a Yamaha RX-V567 receiver/amplifier. The mobo runs the Realtek audio system supplied with the mobo, which has 5.1 Analogue outputs, coax and Optical out. On...
Using an External Sound card
Hello all, as my internal laptop sound card doesn't support SPDIF out - i've decided to go with an external sound card and through the external sound card - hook it to my receiver for 5.1/7.1 sound. My question is how is it that i would connect my external sound card to my receiver. Say i was to...
Output sound to external DAC
Hello all, I am new to the forums and my laptop.However I have one question about my sound, Is it possible to take the sound from my laptop without is passing though my laptops DAC (Digital to Analauge converter) and feed the sound into the DAC on my Cyrus CD player 6XP (2010...
Need external sound card
I have an Alienware Area-51 7500-R4 with intergrated Nvidia C-55-MB. I recently installed Windows 7 (Custom, clean installation) and I only have sound on my two front speakers, no center or rear speakers. Alienware support is unable to help and I was told I could not install an internal soundcard...
