Windows 7: Realtek High Definition Audio and Intel Display Audio
03 Nov 2014   #1
jim97219
Windows 7 ultimate 64 bit
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one?
In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High Definition and Intel Display Audio. I don't understand how Realtek High Definition Audio drivers work in relation to the Intel Display Audio drivers. If I go to Control Panel/Hardware and Sound/Sound then Playback, there are four options, as you can see from the picture below.
I'm guessing that if I choose the receiver as my default device that I'm using the Intel Display Audio drivers and any of the other three options that I'm using the Realtek drivers. Is this correct? If the receiver is the default device, everything works fine; I get sound from sites like cnn.com and I can listen to internet radio, etc. However, if Speakers are the default device, I don't get sound. Is this normal? If so, what's the reason for having Realtek? If it isn't normal, will I notice a difference if I use the Realtek drivers? If I would see/hear a difference, how do I get them to work?
04 Nov 2014   #2
fireberd
The RealTek is for the regular PC sound. The Intel Display Audio is for HDMI sound. If an HDMI cable is plugged in Windows will automatically default to the HDMI as the "default playback device". If you have an HDMI cable plugged in and want the PC sound you must manually change the playback device. If you want both HDMI and PC audio, you can't have that as Windows will only allow one default audio playback device.
Does this answer the question?
04 Nov 2014   #3
jim97219
Yes, it does answer my question. I do have the PC connected to the receiver only via HDMI so the RealTek drivers are basically worthless unless I connect the PC to the receiver using the jacks in the back of the two units. Somehow, I had the idea that the RealTek driver could be used instead of the Intel one and that it would somehow be a better way to go.
I most appreciate your great explanation.
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
conexant high definition audio and intel(R) High Definition Audio HDMI
i have a gateway computer and i want to record some audio from my computer. i looked online how to do this and stereo mixer kept coming up. i looked in my sound and show disabled and disconnected devices are both selected and i do not see stereo mixer in the list of recording devices. can someone...
Realtek High Definition Audio problem
I have a new Dell PC that has Realtek High Definition Audio. As best as I can describe it, while watching videos or in a game, it periodically and with no particular intervals of time, will momentarily (no more than a second) pause and I'll hear a buzz. It then carries on as if nothing had...
Realtek & high definition audio?
HEY Everyone,I do not know if i have been the biggest dummie on the planet eart,i have installet high definition audio drivers witch i thourgt came from REALTEK,but when i open audiounits there only is high definition audio and before it said:realtek high definition audio,there is not ecxatly a...
Hi guys..now we all know ...this is golbal problem..i have instaled my windows 7 ultimate x86 and no drivers works for me...like always :Code 10 problem ...last time ..a xp driver works ...but i can't remember the version that i used... Maybe this will help you...
Drivers
