Windows 7: my keyboard sound control ke dp not work when other audio device is on
05 Nov 2014   #1
madman2z
WIN 7 Ultimate x64
as the title show my keyboard's audio controls stop working when other audio device set as default but when the keyboard is the default audio device they work just fine ,and as i have a subwoofer and a headphone it is painful to change the volume manually
i have a perixx periboard 304 which have a built in speakers and doesn't have a driver of its own
11 Nov 2014   #2
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
Use the other audio device and adjust the sound from within windows 7 via right click of Playback Devices/Mixer via the speaker icon in your task tray?
Keyboard as audio device would only control that audio, unless there was a specific driver for windows 7 to specifically handle those duties with that keyboard, and looks like you answered that one; no driver.
I visited the Perixx website, indeed listed OS support ended at Vista, I would try using the Vista driver anyway, just in case, looks like tech from 2007, so indeed Windows 7 was not out yet.
11 Nov 2014   #3
madman2z
WIN 7 Ultimate x64
ok thank you so much for looking into it , i hoped to find a third party program to do the trick i didn't find one , if u can help with that i would appreciate it , if not its okay i just have to wait tell i save enough money to bu new one
No audio but the green sound bar on the volume control is moving?
Hey there! A few days ago I changed my hdd because the last one got corrupted and had a lot of bad sectors so I installed a new windows 7 OS. Everything was smooth until the sound suddenly stopped. I wasn't doing anything in particular. I noticed the green bar on the volume control is moving but I...
High Definition Audio Device - No Sound
Hi everyone. I bought my mom a refurbished PC and no sound comes out of the speakers. I have made multiple attempts to update the sound driver with no luck. The salesperson over the phone told me I needed to download a new sound driver, but offered no help in identifying which one. I have...
New keyboard volume control buttons don`t work
My new keyboard works, except for its volume control buttons and its l<< >ll >>l previous play/pause and next buttons. Why is this and how do I get them to work?? My keyboard is a wireless Logitech K360
Hardware & Devices
NO SOUND and my Realtek HD Audio will not open from the control panel
Windows 7 86. I have NO SOUND and my Realtek HD Audio will not open from the control panel. I have reinstalled the drivers and used system image to recover but it has not solved the problem. I have used this system image before and it work perfect. I think it is a hardware problem but how can I...
5.1 Sound doesnt work at Realtek High Definition Audio Device
Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is...
No keyboard sound control.
I just D/L sound driver 2.49 and now my K/B mute and volume controls don't work. Is this something to do with the driver or is it something else?
