No sound - help please!
  1. Posts : 13
       #21
    A clean install
  2. Posts : 13,354
    Windows 7 Professional x64
       #22
    Okay, just wondering.
  3. Posts : 1,179
       #23
    Since you will not fill in the SPECS, so we can see what Sony Vaio your using... What is the Model #.
    when you open control panel --> open sound --> then open sounds.
    make sure you have Windows Default checked.
    move down an see if you can hear any of the MS default sounds, like startup or alerts .
    If you move on the control panel --> system --> device manager
    do you have any yellow markers or any RED markers.
  4. Posts : 13
       #24
    Well, I did a clean install and it's still silent. I've noticed though that there are none of the Windows default sounds. Yet Windows Default is listed as my sound option.
    Any further ideas?
    Stephen
  5. Posts : 13,354
       #25
    Look, we really need your system specs. Please check out the link for instructions.
    https://www.sevenforums.com/general-d...tem-specs.html
  6. Posts : 13
       #26
    Sorry to be so useless. I've talen this screenshot which I hope has the info. I can't work out what goes where in the system spec screen...
    Stephen
    Attached Thumbnails Attached Thumbnails No sound - help please!-system-specs.png
  7. Posts : 13,354
       #27
    This is a very strange case to me, and I know of no solution off the top of my head (as you can probably see). The best I can do is experiment and try different things. So, be patient with this, as I am learning too.
    Go to this page, and download "Vista, Windows7 Driver(32/64 bits) Driver only (Executable file)". Do not run the file yet. Go into Device Management again and uninstall all audio drivers. Do not reboot the computer. Run the executable you just downloaded, and reboot as necessary. Let's see what happens.
  8. Posts : 13
       #28
    Hmmm. Well I tried that, and still no sound.
    This is all very odd.
  9. Posts : 13,354
       #29
    Do you have any headphones or speakers you can try?
  10. Posts : 9
    Windows 7 Ultimate 32bit
       #30
    Hallo! my motherboard is ASRock ALiveSATA2-GLAN and the sound card VIA VT8237A High Definition Audio Controller. i have installed windows 7 but have no sound. have installed many drivers but nothin, everytime says no audio output devices installed. is my soundcard compatible with windows 7 or is it an another problem? can someone help me please! thx
