#31
Hello, axxo. Welcome to the forums! Could you please post you system specs?
https://www.sevenforums.com/general-d...tem-specs.html
hello Jonathan King! i have posted some system specs. all drivers are installed without a problem and the sound driver to, but there is no sound.
ok, here is the screenshot control panel -> sound. i hope it can help
Okay, reboot you computer and enter the CMOS. This is usually by pressing F2 or Del during the POST. Navigate to the Advanced tab, and select "Chipset configuration". Confirm that any audio options are set to Enabled.
Caution: messing around in the CMOS is risky. Do not change values unless you know what you are doing.
I've done just as you said, all audio option are enable. in the device manager in the general tab i have this message: This device cannot start. (Code 10)
