Windows 7: Creative X-Fi Xtreme Audio plays no sound
07 Nov 2014   #11
erDi89
I'm not 100% sure about the compatiblity. It's a custom computer I bought in 2007, so it could be it's not Windows 7 compatible. I've no box where i can see it's compatible or not...
I tried to load custom driver also but they doesn't work.
07 Nov 2014   #12
fireberd
There were problems as I mentioned with some model Xfi cards. Considering it is a 2007 model I suspect its one of those.
Creative X-fi Xtreme Audio
Bought this card today. Because it said support for vista, I thought it would work in Windows 7 as well. Installed the card and I had immediately sound. Then I went to the creative site to install the drivers because I had only control over the volume. There was no EAX, no bass control, nothing....
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Does anyone know where i can download drivers for this card for the Windows 7 RC1? ive tried the Beta drivers off Creative and had no joy, the ones that came out when the "leaked" RC1 was out and im gettin majorly cheesed off.... ive got everythig else set up how i want except the fact ive no sound...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
