Windows 7: Creative X-Fi Xtreme Audio plays no sound
06 Nov 2014   #1
erDi89
I installed my soundcard, everything works perfect. I installed drivers and i get no trouble at device manager. After I plug my headphones in and try to play music, i get no sound. At the sound options in windows i see the soundcard and it looks like it works, because the green bar goes up and down. I read that i need to turn onboard sound off in bios. I couldnt find it in my bios (Award Software F4), dont know why, so i deactivate onboard sound at device manager but it didnt work. Maybe someone knows the problem and can help me
Best regards,
erDi
Windows 7 Ultimate 64bit
06 Nov 2014   #2
fireberd
If you have installed a separate sound card, the front panel headphone jack connection has to be moved from the motherboard to the separate sound card. If you didn't move the connection that is probably your problem.
Depending on the age of the PC and the BIOS, the on-board sound could be labeled "Legacy Audio" in the BIOS.
06 Nov 2014   #3
erDi89
Thank you for the help. I opened my computer and saw that there is a cable at the soundcard which isn't fitted. There are letters on it: AC 97 (http://ask.creative.com/wwimages/aud...ontpanel2a.jpg). Did I understand you correct and have to connect this cable to the mainboard?
06 Nov 2014   #4
fireberd
The HD Audio is the preferred connection as it has jack sensing that the AC97 does not have.
The cable must be connected to the SoundBlaster sound card to have front panel headphone audio from the SoundBlaster.
06 Nov 2014   #5
erDi89
Ah now i understand, but that can't be the problem, because the front panel headphone jack connection has already been moved from the motherboard to the separate sound card.
06 Nov 2014   #6
fireberd
Has the front panel headphone jack ever worked? Try the AC97 connector and see if works with that.
Does the PC speakers work with the SoundBlaster? Try plugging the headphone directly into the Speaker jack on the SoundBlaster and see if the headphones work.
06 Nov 2014   #7
erDi89
I'll do it tomorrow and give my experience. Thanks
07 Nov 2014   #8
erDi89
The front panel headphone jack just works with Onboard sound. The AC 97 connector doesn't work, Soundblaster doesn't work with speakers...
07 Nov 2014   #9
erDi89
System control -> hardware and sound -> sound -> right click SB X-Fi Xtreme audio -> properties ->connector information -> no connector informations available
Is that normal?
07 Nov 2014   #10
fireberd
Sounds like the SoundBlaster requires a custom front panel connector. I ran into that with Dell's that used one model Xfi sound card.
Is the Xfi fully Windows 7 compatible? I remember issues with some model Xfi cards not being supported by Creative for Windows 7.
Creative X-fi Xtreme Audio
Bought this card today. Because it said support for vista, I thought it would work in Windows 7 as well. Installed the card and I had immediately sound. Then I went to the creative site to install the drivers because I had only control over the volume. There was no EAX, no bass control, nothing....
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Does anyone know where i can download drivers for this card for the Windows 7 RC1? ive tried the Beta drivers off Creative and had no joy, the ones that came out when the "leaked" RC1 was out and im gettin majorly cheesed off.... ive got everythig else set up how i want except the fact ive no sound...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
