Windows 7: high definition audio device not plugged in
08 Nov 2014   #1
fattymike
windows 7 64bit
hi guys my audio seams to be having problems
randomly my speakers are saying they not working, im getting sound through my screen but i cant get my surround sound to work.
i have tried a few things but really have no idea what im doing any help would be great
thanks
ive added some photo to help
high definition audio device not plugged in-20141109_081920.jpg high definition audio device not plugged in-20141109_081946.jpg high definition audio device not plugged in-20141109_081957.jpg high definition audio device not plugged in-20141109_082007.jpg
08 Nov 2014   #2
Layback Bear
Windows 7 Pro. 64/SP-1
You ask about your speaker system but you don't tell us any information about your speaker system.
What speaker system do you have plugged in?
What ports do you have them plugged into.
We need you to fill out your system specs completely like mine.
This tutorial by Brink should help.
System Info - See Your System Specs
10 Nov 2014   #3
dsperber
Quote   Quote: Originally Posted by fattymike View Post
Your Playback Devices screenshot shows interesting things, but not something that would produce surround sound. You don't have the correct device checked as "default" for that to occur.
It looks like you have your Samsung display (which obviously has speakers in it) selected as the default. So that's where digital audio is being sent... to your monitor, not to your surround sound system through a different connection.
Your "speakers" device says "nothing plugged in", so I assume you don't have computer speakers on your desk.
You show "digital audio (HDMI)" available (presumably there's a cable connected, going to an HDMI input on your surround sound system), but it's not checked as the default. So if this is how you thought you were going to be delivering digital multi-channel audio to your surround system, then you must check this one and push the SET DEFAULT button. Then you'll get multi-channel digital audio delivered via that HDMI output path to your sound system.
Or, if you intended to use "digital audio (S/PDIF)" which I assume is a coax connector with coax cable going to your sound system, then you need to check that one as the default. Again, once this is checked as the default then this is the output path your digital audio will be sent out through, to your surround sound system.
But with your Samsung monitor currently checked as the default Playback Device, that's why you're not getting digital sound delivered to your external surround sound system.
Also, when you do correctly check either the S/PDIF or HDMI device as your default playback device, don't forget to also look at the "supported formats" tab (shown when you push the Properties button), as well as be sure to pick the multi-channel speaker configuration (when you push the Configure button, where you can also "test" each channel solo to be sure you get sound from each speaker). You want to designate a multi-channel speaker setup (Configure), and support for all multi-channel audio formats (Properties).
If you want to use HDMI to deliver audio to your surround sound system, and also use the same HDMI path to deliver video to your Samsung display, you need to have two HDMI cables. One goes from PC sound card HDMI output to the AVR's HDMI input (where the digital audio will be handled), and then a second going from the AVR's HDMI output to relay video on to your Samsung display.
11 Nov 2014   #4
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
Looks like OP does not have speakers plugged into the normally used jack on his PC, usually it's GREEN.
I'd just disable the rest of the devices in that case, and once the normal jack is used you are in business if this is a typical situation?
11 Nov 2014   #5
Layback Bear
That is exactly why the questions in post #2 need to be answered.
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
AMD High Definition Audio (Not plugged in) or not recognized
Hello, I turned on my computer today, and was just playing league of legends when my computer randomly turned off... I thought it could have possibly overheated so I let it stay off for a couple of minutes and then turned it back on. When I did so however, I couldn't get my sound to work at...
Win 7 high definition audio device problem
Hi everyone i have big problem..... so i have an high definition audio bus and i want to uninstall it but i cant when i uninstalled then rebooted my computer windows automaticly installs them again so i cant install other sound drivers bicause that "high definition audio bus" keeps installing it. ...
Low bit rate only available for a high definition audio device.
I have a PNY 570 gtx videocard hooked up with a HDMI to monitor. No matter if I connect it to a audio receiver or to the monitor I only get a maximum of 2 channels and Bit Depths 16-bit. Sample rates are only shown as 44.1kHz and 48.0kHz and the HDMI jack only shows L and R. It wont let me...
Phantom High Definition Audio Device
I'm trying to solve a BSOD issue that I'm having. I don't think that this problem is causing the BSOD, but I want to eliminate it anyway and be sure... I have a stereo system plugged into the rear headphone output, and there is a headphone/mic port on the front panel of the machine, connected to...
No sound (High definition audio device)
Sound works on Win XP (multibooted) but not on Win 7 RC1. I do not know which sound card my computer is using. I have a Samsung Sens Q35 laptop. When I click on the sound icon on the tray on the bottom right, the only device that is listed is Digital Audio (S/PDIF) When I go to the device...
