Windows 7: Replaced power supply, now no sound from speakers
10 Nov 2014   #1
wedgef5
The power supply on my 4-yr old custom build recently gave out. I replaced the PS, and the machine is running normally again, except I can not get sound out of the speakers.
Here are what I believe to be the pertinent facts...
  • Sound worked completely fine prior to PS replacement
  • There are no errors being thrown that I can see
  • Volume is turned up and speakers show that they are un-muted.
  • When sound file is playing, the level indicators are registering positively.
  • Gigabyte motherboard has Realtek HD audio
  • The Realtek audio manager indicates that the speakers are the default output
  • Headphone output via the front-panel jack is working OK
  • Line-in via the rear jack is working OK
  • I have tried both options for headphones mute speakers and headphones and speakers are separate output. Still nothing from speakers.
  • The machine is dual-boot Win7/Linux. Sound from speakers works correctly when booted in Linux.
  • Tried unplugging the front panel header, no difference.
It acts like the speakers are simply muted, but there is no indication of that anywhere. I've messed with it for 2+ hours and have gotten nowhere.
Suggestions?
Matt
10 Nov 2014   #2
fireberd
Try uninstall/reinstall the RealTek. Go to the Device Manager, RIGHT click on the RealTek entry in the Sound section. Then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. This corrects any Windows sound corruptions and may fix your problem.
(Royals/Chiefs fan).
10 Nov 2014   #3
wedgef5
Royals fan, Chiefs fan, AND you fixed my issue! A+ in my book!
Thank you very much!
Matt
11 Nov 2014   #4
fireberd
Great. (I used to live in KC).
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
BSOD 0x116 (stop error) Replaced GPU, replaced RAM, replaced PSU
My monitor goes black and I am forced to reboot. After rebooting I get a blue screen prompt telling me that i've recovered from a BSOD. I've been monitoring them since October. In October, I RMA'd my graphics card. Oct 27. You can see that after I got a new GPU, my BSOD's halted... so...
BSOD Help and Support
Need help with my power supply
Hey guys i been having many problems when i try to play some games they all been crashing lately and everything is pointing to my PSU. So i need to know if my Psu can hold all my hardware while playing heavy games on High settings, or if theres any software that can help me solving that. (srry...
Hardware & Devices
Acer Aspire 5742 no power from dc jack, replaced it, still no power
I replaced the DC jack on an Acer today with a new one. When the laptop has the battery in the power LED shows a power source(unfortunately the battery is dead). When I remove the battery and plug in the charger to the new DC jack, no LED. Hitting the power button results in a flash from the power...
Hardware & Devices
Spilled beer on Power supply and it made crackle sound and rebooted.
As the title saids I did spill some last night on it and the way my vent on the case are set up (cyberpower pc) is that I have open vents on top of the case (terrible design) and the motherboard along with most things are attached on the wall (luckily) EXCEPT the power supply that sat on the bottom...
Hardware & Devices
Hardware Power Consumption-Picking a new Power Supply
Ok, so it's time again for me to pick a new power supply, however, I'm in need of some help determining the appropriate wattage for my hardware setup. AMD Phenom II X4 955 45nm AM3 GSkill Ripjaw X 16.0 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) Corsair TX750w (I dont think its the V2) ASUS...
Hardware & Devices
