Windows 7: DPC Latency Issues, Audio dropouts
12 Nov 2014   #1
czaarek99
Windows 7 Ultimate 64 Bit
So recently I have been noticing pops and crack sounds in my music. I did some research and came to the conclusion that it is the dpc latency. Here is all the information that you might need to help me with this issue.
You can find my system specs on my profile:
Windows 7 Help Forums - View Profile: czaarek99
You can see that all of my drivers are updated here:
Well, there AHCI driver isn't. But I just downloaded it from ASUS website but the program still shows it isn't updated.
Here is a log from latencymon:
Private Paste - Pastie
Here is the screenshot of latencymon:
I don't know what to do anymore, I have pretty much updated all the drivers. This problem is pissing me off extremely. And oh, I did try a clean install of windows too (but obviously I had to re install all my drivers)
12 Nov 2014   #2
fireberd
Here is how to post screenshots on this forum:
I notice Avast is one of the items in the latency mon. Disable that and see if it helps.
Also, if you have a wireless internet connection, wireless is known to cause the problem you are having.
12 Nov 2014   #3
czaarek99
You could click the link, but I'll embed them for your ease.
12 Nov 2014   #4
fireberd
I did click on the links.
Short Freezes and Audio Dropouts every few mins
Hi I have recently been suffering from some very frustrating problems with my audio output. Every couple of minutes the laptop will (very briefly) freeze up and the sound will cut out for maybe half a second. The freezing is only noticeable in games really. After this the laptop makes a whirring...
I need help with latency issues causing audio pops
Hello everyone, Happy New Year! I just installed my Christmas present to my self, an Audioquest Dragonfly ver 1.2 While it does sound better then the internal sound card I have pops going along with the sound. I researched the problem and found that i have rather severe latency issues,...
Audio dropouts/Pops
This has been an issue on both my old/new PC, I cant ever figure out how to fix this but it's been driving me mad. It randomly just gets worse at the worst times. I ran LatencyMon for a few minutes and got this: Audio pops - Pastebin.com This latency issue has been going on since my old PC, my...
6 months now and still no solution to audio Crackling/Popping/Dropouts
Im desperate here as I simply cannot figure out the solution is and this thing is driving me nuts. I have major latency issues and from DPC checker have figured out that its my network adapters (or at least I think). When I disable both of them, I get nearly perfect sound. Ive re installed...
DPC Latency & sound dropouts
Hello everyone, Recently I upgraded my computer hardware to a new motherboard, graphics card and processor. I moved my old hard disks (from my old hardware) into this new computer, turned it on and it started right up, I just had to re-validate Windows 7, which went without a hitch. ...
Short Audio Dropouts Windows 7-64 bit/MCE
Im trying to solve why I am having short audio dropouts (2-3 seconds)when playing audio and video thru MCE. My system uses Win 7/64 bit with SPDIF audio output to an Onkyo amp. I do not get the dropouts when using the analog pc speakers. I am using Shark007's codecs and have previously used...
Media Center
