No right click available on taskbar
  1. Posts : 277
    Windows 7 home premium 64bit
    Hi all,
    on my laptop when I want to remove a USB flash drive I can't right click on the icon - "safely remove hardware and eject media"....No menu or options at all show up.
    Right click works on all the other icons on the taskbar and anywhere else.
    Any ideas what may be going on?
  2. Posts : 1,670
    win 10
    hi
    are you able to double left click on the icon then choose the device you want to disconnect?
  3. Posts : 72,050
    Hello Harry,
    For now, you might see if either option below may be able to help you to eject the device until you get this sorted. :)
    Safely Remove Hardware Shortcut - Create
    Safely Remove Hardware - Add to Desktop Context Menu
  4. Posts : 277
    Thanks guys,
    Oscer....No, double clicking did zilch.
    Brink...handy for a stop gap remedy but being the stubborn jackass I am I went through everything looking for the glitch. Found the bluetooth was turned off, started it up and the right click is back!
  5. Posts : 72,050
    Perfect
  6. Posts : 1,670
    win 10
    that's good news glad you found the problem
