Windows 7: Intermittent distorted audio with Nvidia HD Sound.
25 Nov 2014   #1
Nizzeh
Windows 7 Home Premium 64-bit
Hi there,
recently I've started noticing that when I'm using the Nvidia HD audio most times when I either start up a program or switch tabs on Chrome my audio distorts and gets slow, this happens across all audio platforms (iTunes, YouTube etc). It's driving me nuts and I'd like to try and find a fix. Tried reinstalling the latest Nvidia driver which didn't work at all. If anyone has any ideas I'm willing to try!
Thanks,
David
25 Nov 2014   #2
fireberd
I notice that along with the NVIDIA audio for HDMI you also list the Intel Display audio. If you are using the NVIDIA, the Intel display audio should be disabled, in the Device Manager. This may not fix your problem, but it will eliminate a potential conflict problem.
If you use the PC audio (Realtek) with speakers or headphones do you have the same problem?
28 Nov 2014   #3
Nizzeh
Hi there,
thanks for the reply! I done another clean install of the Nvidia drivers and it seems to be working now with no distortion at all.
Thanks,
David Nisbet
XPS Laptop screen flickering and distorted nVidia and Intel Drivers
I did a fresh install of windows 7 on my laptop. I then got a DELL engineer from the software team to do a drivers install. But the screen on full resolution has problems. When I turn on the laptop and log in the screen gets all weird and flickers and shows grey lines and its very hard to use....
Drivers
Distorted and crackling audio
I've recently noticed that the sound coming through my speakers is heavily distorted and crackly. It's not the speakers themselves; they have been tested. I thought that the port might be loose, but it happens with anything plugged into the front jack as well. The Audio Troubleshooter from...
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
Distorted audio with IDT High Definition audio codec
Everytime my CPU is forced to do a task like switching wifi connections, openning applications and stuff my audio gets distorted i have no idea why because ive been using my laptop for almost 2 years now and ive been having this problema for about a month now, here is what ive already done: ...
No sound from HDMI device Nvidia and Realtek HD Audio
Hi, I have installed windows 7 Ultimate 64bit and have now found I get no sound through the HDMI device. I had a simlar issue in Vista and found I had to use an older Nvidia Driver 175.97 for Geforce 7650 GS inorder to get this working with "Speaker" as default device...However in Windows 7 even...
Sound distorted
I recently installed Win7 7600 x86 on my laptop but now i have a strange audio problem: playback is slow and highly distorted. The laptop uses integrated Realtek AC97 audio, driver version 6.0.1.6305. But when i connect an external USB soundcard (EMU tracker pre), it has the same problem.
