Windows 7: Play two seperate sound sources using two sound cards on one PC?
29 Nov 2014   #1
W7User123
Windows 7 premium 64-bit
I've got one W7 PC, with one Creative X-Fi soundcard in it, on a motherboard that has built in audio.
I'd like to play two music tracks on my PC at the same time, using any browser or browsers. I'd like one track to be heard on one set of speakers, and the other track to be heard from another set of speakers.
To potentially make things a bit easier, I'm happy to either run two instances of any one particular browser (eg two Firefox browsers open at the same time), or run two seperate browsers (eg one Firefox and one IE).
If there is any software that needs to be bought to achieve this, then I'm happy to buy it. Thanks a lot for any recommendations/advice on this subject.
EDIT:
BTW, the music must be played from a browser(s).
29 Nov 2014   #2
CLassicD
7 ultimate x64
29 Nov 2014   #3
countzero
yeah, i wouldn't play from browser it that's possible.
any halfway decent sound software will let you choose soundcard.
also foobar player.
29 Nov 2014   #4
W7User123
I should have made my original post a bit clearer - the music must be played from a browser. (I'll edit my o.p. now)
30 Nov 2014   #5
W7User123
I found this thread fairly helpful:
Per-Application Audio Device Selection for Win7 64 - Configuration - Windows 7
In it, someone mentioned a program called IndieVolume. At the moment, I don't know whether this Windows XP based software has been upgraded to support Windows 7 64-bit. I've emailed their tech support to find out..
Also in that thread above, someone else mentioned CheVolume, Liberate your Audio.. Their FAQ says that they do support browsers, but at the moment only Chrome. I'll have to install Chrome to see if it does what I need it to do...
15 Dec 2014   #6
W7User123
I got this working by downloading the trial version of CheVolume, version 0.3. I got sound from Chrome coming out of one sound device, and a seperate sound from FireFox coming out of another sound device, all on one PC.
Reoccurring low sound issue affecting two sound cards
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still...
Powerpoint is recognizing sound clip as movie, won't play the sound
At a lab I've spent numerous hours on this animation that I'm entering into a national competition. In PowerPoint I had my friend narrate it, and uploaded to drop-box. It was all working perfectly, but now at home when I downloaded it most all of the sound clips are recognized as movies, and won't...
graphics cards only play mono sound...?
hi, getting a dual dvi card. my onboard video plays stereo both dvd's and anything stereo I watch on the computer/internet. The graphics cards I look at say "stereo sound - no". so if I install any of these dual dvi cards I can no longer get stereo sounds from any videos I watch/playback? I don't...
Graphic Cards
Using two seperate audio sources
I am trying to run audio on my pc and tv at the same time however I can only get one to work. Is there any way to get audio running to both the speakers and the tv simultaneously
Graphic Cards
Sound skips after some time (tried diff. sound cards)
Hello, I used to have Vista on this computer and didn't have audio problems. I've upgraded to Windows 7 and use the latest drivers available for my sound card (Striker 7.1). I have also tried not using these drivers and instead using a USB sound card (Sennheiser that comes with one of their...
Having sound outputted to multiple sources
For instance say I want to output sound through both my external sound card, HDMI audio output and Laptop speakers. How would I accomplish this? I'd actually like to how like 7.1 surround right now my sound is hooked up like this USB to M-Audio Fast-Track Pro
