Windows 7: Front Panel Headphone Jack - Poor feedback issue
30 Nov 2014   #1
TheDeepC
Windows 7 Home Premium 64-bit
Hi! Thank you for taking the time to read this & hopefully help me resolve my issue. May the records state that I'm not the most experienced with computer hardware, but I'm interested in it and have been learning through my friends.
That aside, I recently got a Logitech G230 Stereo Gaming Headset. I've been plugging it into the audio/microphone jacks in the rear of my tower, and they've worked fine.
// Really great headset, by the way; very comfortable and I have no complaints about it as of yet.
Recently, upon cleaning out my tower, I found that there are audio/microphone jacks on the front panel. Who knew? I never really explored my computer tower so this was a neat find for me. I decided to see if my headset would work through them, and lo and behold, the feedback volume was significantly lower than it was in the rear jacks. To my dismay, I couldn't find out why this was, and Google ceased to give me the solution I desired.
Help is welcomed with open arms!
01 Dec 2014   #2
fireberd
I'm not sure of what you are saying. Are you saying the sound volume in the headset is lower than it is plugging into the rear Green speaker jack?
There can be a sound level difference, depending on the impedance of the particular headset. The Green speaker jack on the rear is designed to feed a speaker system which will have a different impedance than headsets. Thus there can be a difference in the sound level.
Dell does not list the technical impedance specs for this model so I can't say for sure what the Speaker and Headphone jack impedances are.
Headphone front jack is far too quiet
Hey Recent problem, basically I've turned up all possible volume controls I can find, tried multiple programs, multiple headphones and earphones, and the problem remains = sound is fine when it's coming out my cheap 2.1 speaker set, but when I use the headphone jack, it's really quiet. It's a...
Front panel headphone jack problems
I've seen similar posts regarding this, however none have helped so I'm starting my own one...hopefully someone can help. I upgraded from Windows XP to Windows 7 64bit. In XP, I used the front panel headphone jack for hooking up to my TV, or headset. Since I've upgraded, this headphone jack...
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Front input headphone jack does not work
I recently run into this problem. The first time I tried to use it, it seems that the green jack for my headphones doesn't work at all. Plug in any pair and they don't even recognize it being there, as seen in Control Panel. What might be the problem? The case has a bad jack, or the connector...
