Windows 7: No Sound! help please...
04 Nov 2009   #1
cheamzy001
Windows 7 Proffesional 32-bits (Built 7600)
i've installed the latest audio driver. but yet it still not making any sounds. what should i do?
OS: Windows 7 Proffesional 32-bits
Mobo: Gigabytes Ep45-UD3L
any ideas?
04 Nov 2009   #2
theog
ME/XP/Vista/Win7
Quote   Quote: Originally Posted by cheamzy001 View Post
any ideas?
What sound card.
04 Nov 2009   #3
cheamzy001
realtek HD. i suppose? on board one.
04 Nov 2009   #4
umarrehman187
windows 7 32 bit
same problem here
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
