Windows 7: Strange sound for no apparent reason
13 Dec 2014   #1
MadforitSteve
Just recently I have started to get the sound that is usually played in association with closing programs/applications but it happens lots of times as if something is happening in the background but nothing shows in the task manager although the order of programs keeps changing quite rapidly.
As far as i can tell it is not affecting performance but it sure is annoying,,the only way I can silence it so far is by turning the system sounds slider down to 0.
I have used several different malware scanners to no avail and also some other tools.
I hope someone here can help me get to the bottom of this annoying problem.
Thanks in advance
13 Dec 2014   #2
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
If you are talking about the sound made when you insert a USB Flash drive, it could be a hard drive or something else connected by USB, such as a keyboard, mouse, web cam or something else. I think whatever it is, does not sound very good. I would try to narrow it down. It could be a USB Header connected to the Motherboard. such as the front panel connections.
16 Dec 2014   #3
MadforitSteve
Different Sound
No, It is nothing like the USB sound that you mentioned,,,,the only thing i can find in control panel settings is the sound that is normally associated with closing a program,. But like I said it seems to happen extremely frequently and also for no apparent reason.
I think that there could well be some well hidden malware somewhere that is causing this although so far none of the scans that I have done have came up with anything.
I hope someone can help me get to the bottom of this annoying problem.
16 Dec 2014   #4
Layback Bear
Windows 7 Pro. 64/SP-1
Right tick on your Desktop and select Personalize.
Tick on Sounds and then select Windows default.
Then remove everything except your mouse, keyboard and monitor.
Verify that those connection are proper on those three things.
Let us know if that solves your problem.
Could you post what programs you use to scan with?
18 Dec 2014   #5
MadforitSteve
No difference,
Scans I have done are as follows.
Malwarebytes Anti Malware and anti rootkit
SuperAntiSpyware
Emsisoft
RogueKiller
TDSSKiller
ASWMBR
AdwCleaner
If you would like me to re run any of these I will be more than happy to do so although I do think something else is causing the problem,,either that or something that hasnt been recognised yet as nothing seems to shopw up.
SSD drive full with no apparent reason.
Hi, the drive that I got my windows and main programs appears to be full with no apparent reason. I tried using the "Disk Cleanup" tools and basically all hd-related tools in IOBit's advanced systemcare -software. Here's a screenshot of the relevant info: The "Disk doctor" in IoBit's...
Hardware & Devices
Can't hear any sound for no apparent reason
Hi guys, My computer audio was working fine yesterday. I left it on throughout the night but now all of a sudden, I can't hear anything from it. I've checked a few common problems that may occur but to no avail. I've tried checking the: - Sound level sliders and mute settings (placed all on...
BSOD all the time for no apparent reason
Hi I have a custom built PC Windows 7 x 64bit which just keeps freezing after a few minutes of using it for no apparent reason. Error message here any help appreciated because when it works its a cracking little PC :D Thanks in advance to all you very cleaver people.
BSOD Help and Support
debug.log on start-up for no apparent reason?
Corrupt Index file Unable to move the cache: 5 Unable to move cache folder C:\Users\Gideon\AppData\Local\Facebook\Messenger\fbmessenger.cache to C:\Users\Gideon\AppData\Local\Facebook\Messenger\old_fbmessenger.cache_000 Unable to create cache WinHttpGetProxyForUrl failed: 12167 Corrupt...
Software
BSODs for no apparent reason
BCCode: deaddead BCP1: 000000000F010012 BCP2: 00000000001C0410 BCP3: 0000000012BC0000 BCP4: 0000000000000000 OS Version: 6_1_7601
No signal detected in WMC for no apparent reason
I have had my current PC for over a year, running Windows 7 with Media Center, and for almost the whole time I have had my OTA antenna hooked up to my PC and have never had issues. Today I decided to clean out the dust inside my computer, so I unplugged everything, including the coaxial cable from...
Media Center
