Windows 7: Realtek HD Audio Problem: Headphones appear as "Speakers"
15 Dec 2014   #1
rallym
Win 7 Home Premium 64bit
Dear all,
my speakers do work. When i plug in my headphone at front the speakers get replaced, means I head everything through the headphone.
Headphones themselves aint shown under "Sound":
Realtek HD Audio Problem: Headphones appear as "Speakers"-1.png
It appears that both, speakers and headphones are used as one source for audio-out.
Realtek HD Audio Problem: Headphones appear as "Speakers"-2.png
However, I want to use both. Headphone should not automatically replace Speakers.
What do I make wrong? Setting for simultaneous Audio can't be found with this new Realtek R2.75 as previously?
Thanks a lot for your support!
15 Dec 2014   #2
Shimshom
Hi and welcome to 7F. You won't see a separate entry for standard headphones in the Sound properties and normally you would find the option to disable front panel jack detection in the Realtek Sound Manager and often they seem to bury that option somewhere obscure so try to look for it again in the Realtek Sound manager
16 Dec 2014   #3
rallym
Thanks for your answer.
However, this happens with my brand new PC. With my former one, I had a separate entry for headphones AND I also know about this setting of simultaneous usage of speakers / headphone in the Sound Manager. It just is not visible in this new version of Realtek.
best regards,
17 Dec 2014   #4
rallym
Solved. Had to deinstall HD Audio Driver. Plugin headphones. Restart. Windows installed basic audio driver automatically and see there: headphones entry is back and I can manage both audio-outs.
Weird.
Realtek HD Audio - No Sound through speakers \ headphones
Hi, This is driving me mad now also as soon as I google it there seems to be hundreds of similar problems.. New custom PC and cant get any sound from the rear speaker jack of front headphone jack. Sound is playing as the volume leve indicator is moving up and down and is green yet no sound...
Realtek AC'97 Audio - Cant hear any sound from headphones or speakers.
I just bought a pc, windows 7 32bit. I tried to use my headphones but couldnt hear any sound, also tried speakers still no sounds. The green bar goes up on the volume control tho. I have tried downloading some drivers, but they didnt work. Im a novice when it comes to things like this, can...
Realtek HD audio recognizes my headphones as speakers
Hello When I plug in my headphones to the back of my computer where my onboard soundcard is located, it seems that realtek detects my headphones as speakers, and as a consequence, the volume is way too low. When connected to the front of my computer however, realtek detects my headphones...
Realtek HD Audio - Speakers "Not plugged in"
Hello, I'm new. So sorry if I do not post in the common format. Recently, I had downgraded to Win 7 Ultimate from Windows 8, for various reason. So I do my normal things, download all the drivers, and programs that I would need. Sadly, I had lost my motherboard's drivers disc. So, having...
realtek audio not detecting speakers or headphones.
I have an Asus M4A89TD pro / usb3 that has Realtek audio onboard. I have just finished my build and have never been able to get any sound from any of my IO ports. None of the ports recognize anything that I plug in (i only have 2 sets of 2.1 speakers, one uses a single light green jack and the...
"No speakers or headphones are plugged in" Win7 ult. x64 HDMI>AVR>LCD
Hello Everyone, I have been a lurker for a while but have now created an account to ask for help since searching has been not helpful thus far. My PC: Profile is filled The problem:
