Windows 7: how to turn off audio from speakers while using headphone?
20 Dec 2014   #1
quicqsolution
Microsoft Windows 7 Ultimate 64-bit SP1
Hi,Everyony
I just installed windows 7ultimate 32bits yesterday on my 4 computers.
but now i am facing a problem on all computers. when i plug the headphone stereo pin then the audio voice come from headphone and also from computer's built-In speakers
I check from font and back side of computer but result is same.
please help me how to fix this problem because i don't want to hear voice from speaker.
20 Dec 2014   #2
fireberd
If your "My system specs" is the PC's you are referring to. You are apparently using a separate sound card (Creative 7.1), disable the on-board sound in the BIOS. Also, you have to move the front panel headphone connection from the on-board audio to the Creative sound card. In addition many sound cards have a control panel option to mute the speakers when a headphone is inserted (usually the default) or have both headphone and speaker on when headphone is plugged in.
Audio coming from both Headphone and Speakers when headphone used!!
Hello Guys, had this problem while,tried many of the solutions to resolve and failed,finally reset the system to factory settings thinking things will be back to normal,but still it exists!!:cry: *Asus g74sx- windows 7 ultimate,Realtek Hd audio. Just saw the new Realtek Hd audio driver...
Headphone speakers acting like a mic??
Heya, I have an HP Pavilion EP dv6 and I have a skullcandy "lowrider" headset, I was messing around with it today because I thought the microphone was broken, but I kept heard like a shuffling noise, and I sneezed and while my face was aiming towards the speakers on the headset, and I heard it! ...
Sound from speakers when headphone plugged in
Hello I have my headphones plugged in but sometimes when I open programs and CPU % goes high then sound switches to speakers. It only happens for a short time (under a second). Please help
built in speakers / headphone issues
Hi all I'm currently using a HP Pavilion dv4-1433us laptop. The problem I'm having is this: When I have my 'Default Device' (under Sounds >> Playback) set to Independent Dual Headphones, I get perfect sound from Headphones / Exterior speakers, but the second I disconnect all exterior...
USB headphone/mic vs speakers
Is there any way to make my external speakers and USB headphones work simultaneously, or at least have it where plugging in the headphones makes them work and turns the speakers off? The way it is right now, I have to open the Sound control panel and click the "Set Default" button to switch...
How to set headphone/speakers as a recording device?
Hi,I have posted a thread about stereo mixer not working in Windows 7,well it still doesn't.I have tried everything possible (updating drivers and such),I can see it,I have enabled it but there is no sound coming from it,while it works perfectly on vista.I have been working on this issue for a...
