Windows 7: REALTEK|using front speakers through rear output jack - possible?
21 Dec 2014   #1
Supdoc
win7
hi
Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable
I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right channels worked!
Is it possible to make the rear black output to work as FRONT speakers ?? this way ill be able to have both speakers and headphones available at the same time
In other simple words:Can I use rear speakers as FRONTS ?(when connector to the black rear output)
BTW;I don't wanna use the front panel, only the back panel
Thank you!
21 Dec 2014   #2
fireberd
Easiest way would be to use an external speaker switch, since you do not want to use the conventional method with the front panel headphone jack.
With an external switch you could select either the speakers or headphone.
I don't know what sound you have but the only option is RealTek audio is to mute or not mute the speakers when a headset is plugged into the front panel headphone jack. There's no way, that I know of, to route primary audio to some other jack.
21 Dec 2014   #3
Supdoc
win7
It's kinda stupid that we can't use the rear-out for front speakers, hardware-wise it has right/left channels anyway, so it's only a matter of quick software/driver codding
I guess I'll just connect the speakers to the front panel
Thank you
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
Realtek Mute Rear output when front input is plugged in
This doesn't work. Very irritating. (I don't know if this RealTek sticky at the top of this forum is a solve for this, I'm not hot on registry changes and I'm not sure if this is a fix for this issue.) Firstly I have to turn off the front-panel detection in order for the front panel to be...
Cannot record from front or rear jack
W7 does not seem to recognize front or rear mic jacks. Tried with 2 mics, one brand new, I am using built in W7 recorder. Thanks, Luis.
Can't get Rear Audio jacks to work While cable connected to front jack
I am fairly new with W7 so please excuse my inexperience with this. I have headphones connected to front headphone jack (Dell Inspiron 560 W7 Home 64). I want to have cable connected to rear jack (for speakers in other room). I can't get audio from the rear if anything is connected to the front...
Front headphone jack does not mute rear speakers
Asus M4A78-EM motherboard using Realtek drivers from Asus site. The front headphone jack did not work until I installed the Realtek drivers from the Asus site. Actually they didnt work until I checked on Disable Front Panel Detection. That got it going but the rear speakers are still...
