Windows 7: Audio dropouts/Pops
27 Dec 2014   #1
daronmal
Audio dropouts/Pops
This has been an issue on both my old/new PC, I cant ever figure out how to fix this but it's been driving me mad. It randomly just gets worse at the worst times. I ran LatencyMon for a few minutes and got this: Audio pops - Pastebin.com
This latency issue has been going on since my old PC, my current one is only less than a month old and its been doing it to. Lots of audio pops and dropouts.
A lot of the main ones I see come up are:
hal.dll
ataport.sys
ndis.sys
USBPORT.sys (Fixed by disabling USB3.0 apparently)
NETIO.sys
iusb3xhc.sys
28 Dec 2014   #2
fireberd
You list the sound card as AMD High Definition Audio Device, which is sound for HDMI, not the regular PC sound. Are you using HDMI?
The regular PC sound would be RealTek, IDT, etc.
Are you using Wi-Fi or wired cable for internet? Wi-Fi is a known cause of your problem.
28 Dec 2014   #3
daronmal
I have Realtek then.
I have a wired connection too.
28 Dec 2014   #4
fireberd
Do you have the Gigabyte Easytune installed? That is known to cause the problem you have.
28 Dec 2014   #5
daronmal
Nope
28 Dec 2014   #6
fireberd
The iusb3xhc.sys comes up quite a bit when doing google searches for your problem. From what I can find it has something to do with the USB3.0.
28 Dec 2014   #7
daronmal
Yea I figured it was so I went into BIOS and disabled 3.0 and move all my stuff to 2.0, but it didnt seem to change anything.
29 Dec 2014   #8
fireberd
I have USB 3.0 and do not have the problems, so it may not be USB 3.0 but some driver. I use my PC for my recording studio so Latency, noises, etc are very important. My system is clean with the Latency Mon. I was using a Gigabyte GAZ77X UD5H motherboard but it developed problems and I've switched to an ASRock Z77 motherboard - both have USB3.0.
As your old PC and new one have the same problem, what is common (same) with the two? Hardware or software.
BTW, here is he way to post screenshots on this forum.
29 Dec 2014   #9
daronmal
Well hardware-wise, the only things that are the same are 2 HDD's that I took from my old PC to my new one. My old one was an older version of the stock Dell Inspiron 620 with an added graphics card and HDD were the only 2 aftermarket items. Software, very similar, same antivirus, same PC diagnostics and cleaning software, same games, same browser...etc.
29 Dec 2014   #10
fireberd
Considering you are using the old hard drives from the Dell system, did you do a complete "clean" install on the new system? (Clean install - reformat the hard drive and install Windows, drivers, software). If you didn't do a clean install the problems you had could very well still be there.
 Audio dropouts/Pops
Short Freezes and Audio Dropouts every few mins
Hi I have recently been suffering from some very frustrating problems with my audio output. Every couple of minutes the laptop will (very briefly) freeze up and the sound will cut out for maybe half a second. The freezing is only noticeable in games really. After this the laptop makes a whirring...
Audio pops/cracks
Hello guys,I`ve been trying to solve this problem for almost a week.I`ve clean installed windows 7 64 bits,and since then,I have cracks in both my headphones and speakers which occur like every 1 minute,and it seems I can only hear `em while I`m listening to music.I`m sure its not an mp3/player...
Audio pops/cracks,probably because of hal.dll
Hardware & Devices
DPC Latency Issues, Audio dropouts
So recently I have been noticing pops and crack sounds in my music. I did some research and came to the conclusion that it is the dpc latency. Here is all the information that you might need to help me with this issue. You can find my system specs on my profile: Windows 7 Help Forums - View...
6 months now and still no solution to audio Crackling/Popping/Dropouts
Im desperate here as I simply cannot figure out the solution is and this thing is driving me nuts. I have major latency issues and from DPC checker have figured out that its my network adapters (or at least I think). When I disable both of them, I get nearly perfect sound. Ive re installed...
Short Audio Dropouts Windows 7-64 bit/MCE
Im trying to solve why I am having short audio dropouts (2-3 seconds)when playing audio and video thru MCE. My system uses Win 7/64 bit with SPDIF audio output to an Onkyo amp. I do not get the dropouts when using the analog pc speakers. I am using Shark007's codecs and have previously used...
Media Center
