Windows 7: Realtek Audio Issues-Cant enable auto popup notifications/low sound
29 Dec 2014   #1
n1ghtrunner
Windows 7 64bit
I've just completed an upgrade on my rig and I replaced the Mobo, CPU, and RAM. The MOBO change required a fresh install of Windows 7 (64bit), which I did, and I proceeded to install the motherboard drivers from the CD provided. My last motherboard was a Gigabyte. The current motherboard is an ASRock H97 Performance Fatality motherboard.
With the new build I've had challenges in getting Realtek to work as expected. I use this rig to game, so sound is very important, and unfortunately the sound is the ONLY area I have challenges with at the moment. Here are the issues:
1) I noted that the level of sound is very low when plugged into the rear panel - much lower than it was previously
2) I noted that now when plugging my headphones in the rear panel, I do not get the auto popup that I used to get asking me to confirm that I just plugged in headphones - i get nothing. I suspect that this is WHY the sound is low - the system thinks im plugging in speakers, when I'm not doing that at all - I'm plugging in headphones
3) I cannot enable the auto popups in the Realtek Manager - I go in there, I click on the folder image, and I get something about enabling/disabling the front panel - nothing else. There is no option for me to enable auto-popups
4) I cannot click on the port image within Realtek to define how i want the port to be used - nothing happens.
What I have done:
1) I tested on the front panel and the sound is much louder. I still dont get any popups asking me to confirm what I've plugged in, but it seems the system is assuming I'm using headphones, as its MUCH louder (what I was used to level wise on the old mobo). There is a bit of static on the front panel (not much, and way better than last mobo - but it's not crystal clear) so I'd prefer to just get the rear panel working properly!
2) I updated the Realtek drivers with the latest drivers noted in the sticky in this forum, and it changed absolutely nothing.
So I'm totally stumped as to what to do here. Is there something wrong with this MOBO or is it just limited in some ridiculous way? I'd think not but this is driving me insane. Please help!
Thanks.
29 Dec 2014   #2
fireberd
I went from a Gigabyte Z77 UD5H motherboard to an ASRock Z77 Professional Fatl1ty. I didn't notice any change in the sound.
Plugging into the rear GREEN speaker jack will not detect headphones, just that a "speaker" was attached. My RealTek does not show headset when the headphone is plugged into the headphone jack, just shows "Speakers" connected.
If you installed any enhancement to the Sound, check that for any volume level adjustments.
29 Dec 2014   #3
n1ghtrunner
Windows 7 64bit
ok so the issue here is that the sound level has decreased substantially from the rear panel when using headphones. I dont have speakers, so I can't test that. On the old mobo, also realtek, when i inserted headphones in the green rear jack, I got the autopopup, and sound levels were fine. Now they are not and I cant enable the popup. So I want to work out how this can be fixed.
30 Dec 2014   #4
fireberd
On both of my systems (I tried it), one is an ASRock Z77 Professional Fatal1ty motherboard and the other an ASUS Z77 LE Plus motherboard and both Win 7 and Win 8.1, neither have a popup that says headset connected when I connect them to the green speaker jack on the rear. Neither show a headset connected when they are connected to the headphone jack on the case front panel.
I don't think that has anything to do with your low level problem. As the front panel headset level is OK, it suggests a hardware problem with the rear speaker out that is causing the low level. Also, make sure you have "Stereo" selected as the speaker type,.
30 Dec 2014   #5
n1ghtrunner
Windows 7 64bit
ok. When you double-click on the Realtek icon in your tray, is there a Folder icon on the right above the jack images, and in clicking on that folder image, is there an option to enable the auto-popups?
I had this on the previous system. I no longer have this. I feel like there must be something incredibly obvious that I am missing here! I tested this on another computer, and the option is there, and the popup does happen, and I can select headset on that computer.
30 Dec 2014   #6
fireberd
I don't have the option on my system.
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Realtek Audio HD Manager does not auto-detect speakers
Hi all, I recently updated my AMD drivers as Civ: Beyond Earth asked me to. Since then, the Audio Manager has not been able to detect the speakers automatically. I regularly plug in and unplug my headset and previously the system would detect it being removed and automatically switch the...
No Sound - Realtek HD Audio
My last resort though perhaps it should have been the first but I have been all over the web looking for a solution to this problem, the problem being no sound. Where here I am the speaker icon displaying a red cross and when I try to troubleshoot the issue the troubleshooter tells me no speakers...
Realtek HD Audio Sound Comes and Goes
My sound comes and goes on my HP e9280t. Sometimes I get the realtek hd manager icon telling me that the speakers have been plugged in, and then 1 second later it tells me they have been unplugged. It can keep doing that for minutes until I finally close the message. If I go into the audio manager,...
Hardware & Devices
Low sound issues w/ Realtek HD Audio (ALC889A)
So, first of all let me state that everything else is working great. Windows7 is truly a remarkable OS. The only thing that doesn't work as it should, is the sound. I'm using Logitech's X-530 5.1 system. When compared to XP, the sound is just... Too low. I tried a couple of things, various...
Yesterday I installed Windows 7 Build 7264 32 bit. everything was working right I installed everything and it was all ok and was listing to music in itunes perfectly. I restarted the computer and the sound was gone. First I tried reinstalling the realtek drivers, but the install no longer worked...
