Windows 7: Microphone not Working! (Recording irritating buzzy distorted sound)
01 Jan 2015   #1
Chandrashekhar
Windows 7 x86
My Computer came with preinstalled "Realtek HD audio manager" as an audio driver, at first it was alright but after a year the microphone was recording a very buzzzy irritating sound suddenly. I tried reinstalling Realtek Audio manager but nothings worked and i thought there must be some hardware related issues with microphone and I left it as it is. But one day I installed windows 8.1 on an another partition(Dual boot with windows 7) and microphone is working fine in windows 8.1! but not in windows 7..what can be the problem in windows 7, is there anything i need to reinstall apart from Realtek HD audio manager! Please Help
01 Jan 2015   #2
fireberd
Did you completely uninstall the Realtek, restart the PC and then reinstall? If not that is the next step.
Go to the Device Manager, Sounds section. RIGHT click on the entry for the RealTek and then LEFT click "Uninstall". ALSO check the box to uninstall the driver. Restart the PC and when Windows starts it will detect and reinstall the sound with the generic, basic function, High Definition Audio Controller (assuming it is Windows compatible). Then install the RealTek (which will remove the High Definition Audio Controller (Codec)). See if this procedure fixes it.
As a side note, the 2GB or Memory that you list is bare minimum. You will get much better operation with 4GB (if the PC will handle it).
01 Jan 2015   #3
Chandrashekhar
Windows 7 x86
If went all accordingly as you said but at end everything was same!
02 Jan 2015   #4
fireberd
What program are you using to test the microphone?
03 Jan 2015   #5
Chandrashekhar
Windows 7 x86
I am actually Listening to the device..Recording Devices>>Select device>> Properties>>listen>>apply
Not only in this even recording sound in sound recorder causes this problem ..but this is a bit confusing ..the audio file I save after recording..at first I listen to it its Distorted completely and the same audio after some time is fine! and this problem occurs on every program that uses microphone!
03 Jan 2015   #6
fireberd
With everything you say you have done, it sounds like a Windows 7 OS problem and not a problem with the sound drivers.
Sound Blaster Audigy Rx Microphone Not Working
Hello!I am using the turtle beaches X12 headset. I have just recently installed the Sound Blaster Audigy Rx to my PCs motherboard. And stoped using Realtek Audio Manager and using the Creative SB drivers. After a week, the microphone stoped working(Sound still works) and said "Currently Unavalable"...
Microphone missing enhancements on recording tab
Hello, i have been looking around now for a few days and i still cant find an answer, Am using a sound blaster play usb sound card and it has no option for microphone enchancements, mainly background noise surpression, When i use the default sound on windows system provided by the mobo, it...
Rear'Microphone' and 'Line in' Sound recording devices are unavailable
Good morning all. Could anyone please explain to me how to enable my rear 'microphone' and 'line in' devices in win7 64? Currently they are listed as unavailable(see attached image). The rear 'microphone' input socket has a guitar physically plugged into it, and the 'line in' has a stereo synth...
Laptop freezes and makes buzzy sound when listening to music.
Hello guys, I've had the freezing problem for months and so far no solution. My laptop runs fine when I play games, or browse, as long as i don't watch videos or listen to music, it doesn't mind if online or from my drive. Tried different software but no luck. I would think it's hardware, but i...
BSOD Help and Support
AC'97 Sound (Microphone Device) Suddenly Not working
First post :) OK, so here is my problem (Specs and Already tried solutions below): I was using skype and my microphone was working perfectly. So, I go downstairs, get a drink and return. Only to find that my microphone is suddenly broke. Now it's not the microphone it's self, It works on my...
Distorted microphone - crackling/high pitched
Hi all, I have a Dell Inspiron 1525. After having installed Windows 7 I was not able to record - microphone would not recognise my voice. Now, after having download the SigmaTel Device Drivers I can hear my voice but the background is crackly and the noises are high-pitched. Any suggestions...
