Windows 7: Need Surround Sound
06 Feb 2015   #21
rvcjew
7 Pro x64, 10 Pro x64
Quote   Quote: Originally Posted by web View Post
Quote   Quote: Originally Posted by rvcjew View Post
herd this term a few times not sure what it means i.e."4K Passthrough' does this mean it will let the video source just go thought not mess with it ? ... at all ? ... or are some passthrough's not as good as others and do mess with it ........ and what about the sound, or this about sound
I'm not sure what you mean by this sound also I meant sony and not nosy lol, the 4k passthough if a true passtrough will not touch the signal, that is correct. It will only take its sound signal from it to use for the receiver. The difference when talking 4k is that a receiver with 1.4 HDMI will passthrough 4k at 24/30 fps max and a HDMI 2.0 receiver can do it in that as well as 60fps (if the source can handle it).
Hope this helps answer at least some of your questions.
EDIT: CNET explains it well here. HDMI 2.0: What you need to know - CNET
let me try ask this again because I still don't quiet get it, so the term pass-through doesn't mean it will pass-through unchanged, but it will past through to best of the ability of the said AV which will most probable be HDMI 1.4 or lower fps than 4K, so 4K pass-through of a lesser AV or most things on the market at the moment that state 4K pass-through would reduce picture quality? yes
No, it will pass though unchanged but your biggest issue would be the hdmi spec but since your tv on LG's site says it has hdmi 4k 60fps spec ports (does not say its hdmi 2.0 which is confusing) I would say get a HDMI 2.0 receiver in the first place. It looks like what you want your setup to be is a pass through receiver to handle the audio and the video to be handled by the tv.
EDIT: seems your tv supports this:
07 Feb 2015   #22
web
Windows 7 Ultimate 64bit + Windows 10 pro 64bit duel boot
after all this hassle think I jumped the gun a bit with 4K TV although u have to do it sometime? ... but today re-plugged my old Sony STR-DG910 in just connected speakers and connected to, from Optical out from TV works ok but never liked this unit as surround sound but better than TV speakers for now let 4K catch up with me I think ....... also think my 4K TV (LG 42UB820V) bit of a budget brand will look into the HDMI Speck thing
That said TV picture on ps4 is awesome in vivid (plus animation), not so good in normal TV, HD TV is a little better, but in my local super market the display model showing picture is better than awesome its unreal!!!!!!!!!! but that loop its playing, is filmed in 4K that we don't get yet ....... I assume
08 Feb 2015   #23
rvcjew
Yeah 4k to purchase is around the corner or atm very hard to acquire its mostly done with other means(using a pc as a source and playing 4k content from it), I recommend you just make sure your sony is setup for 5.1 or whatever its speakers are then see if it can see the DTS or AC3 streams from something like this off a usb stick. http://distribution.bbb3d.renderfarm...fps_normal.mp4 Right click the link and save as.
13 Feb 2015   #24
web
Very cool mp4 lol looked amazing on 4K will go back have a look at sound, but first time round sounded good
13 Feb 2015   #25
rvcjew
Yeah, Sintel is also very good. https://download.blender.org/durian/...el.2010.4k.mkv Hope your tv supports mkv's
14 Feb 2015   #26
web
cheers mate can watch this albeit without sound on pc probably just me been stupid lots of settings might let me here but cant copy to USB says its to large only 4.5 GB (which took some downloading ten mins) but wont copy to any USB ??? 32GB 8GB excreta ???
15 Feb 2015   #27
rvcjew
Is your usb formatted as FAT32, as that only supports individual file sizes up to 4GB. Format it as EXFAT or NTFS and it will work. Tv probably supports both.
15 Feb 2015   #28
web
looks like my TV doesn't support mkv's (what ever they are lol) wont work on TV from USB say's it's corrupted and yes USB was fat32 reformatted to EXFAT but still no go on TV .... but then I fort ill play through pc to 4K TV with (HDMI NVIDIA Gefoce GTX 750i) this worked but still know sound ...... was playing using DivX Player this program told me to download AC3 Filters witch I did, bit complicated but got there in the end
upshot was I got to watch the file on pc as well as 4K TV simultaneously but sound only from pc better than nothing had to see now lol
picture on 4K better than PC but 4K whites too white (in Vivid mode) but colours better than PC also PC had some pixilation in parts not on 4K this is amazing stuff should make a new dedicated page level for it lol
16 Feb 2015   #29
rvcjew
if your playing it with pc use VLC and in vlc right click your video thats playing and under audio/devices pick your gpu and the tv should play the sound.
19 Feb 2015   #30
web
cool will try this and report back but having some pc issues at the moment see other post in back up and restore
 Need Surround Sound
how to get 5.1 surround sound through TV's USB
hi......i recently brought sony32EX650 LED TV with Sony DVD player with home theater.and i want to watch HD movies on this TV with surround sound but we know dvd player don't play the Hd quality videos.But on TV's usb we can play those Hd videos and they have 5.1 surround sound also.and i can't get...
Surround sound
Hi all. Upgraded my OS from XP to Win7 (again) Before I had just headphones.. Now I have problem. My sound card Realtek ALC883 @ VIA VT8237A High Definition Audio Controller Cpu AMD Athlon 64, 2200 MHz (11 x 200) 3500+ Motherboard Asus M2V-MX (2 PCI, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video,...
Help with Surround Sound
Hi. I have a ASUS LGA1156 Intel P55 DDR3 - 2133 ATX Motherboard I was told this mobo has surround 5.1 integrated with it. I just do not understand how to use it, or at least I think I don't. What cable do I need and what slot do i have to connect it to.
4.1 surround sound help
i have a 4.1 surround sound system on my Xfi card, my sub woofer is attached to my front speakers, and i wanted to know if anyone here knows how to dedicate all bass to one pair of speakers, that way i dont get such great bass from one side during my gaming, and a horrible bass from the other with...
5.1 surround sound help
I've recently found out that my sound card application (creative audigy) is not compatable with win7 and have yet to find any creative programs that work with my computer. Is there a way around this to still be able to play music on 5.1 surround sound? Like a generic application to play music in...
Surround Sound in BF2142!
Hey all, I've been checking out windows 7 lately, and lately while I've been playing I noticed that there is no surround sound in battlefield! I've googled far and low for a fix, but unfortunately I can't find anything. I have: Windows 7 64bit RTM HT Omega Striker 7.1 - Latest drivers via...
Gaming
