No I meant the device sending the audio and video to your tv, also as Misfit stated you can hook up your old sony av again and try out the audio syncing settings to see if this fixes it for you. Depending on source(desktop vs laptop) I need to set my delay a bit. I only use 1080p 3D though.
am I asking the wrong question here isn't there a product out there that just does sound wired to speakers, but digital from source or has the world gone blue tooth mad ??
What I would do in your situation if you still have the Sony is make the tv output sound to the optical out and run just it to your sony avamp. If your looking for an all around 4k solution you will need to ask others though since I only have experience even at 4k with budget avamps. My avamp is a onkyo tx-nr525 and it has decent 4k passthrough but very limited sound capability. If your tv plays the video fine you might be better off sending it to the tv then sound to the Sony if the you only have like two devices.
herd this term a few times not sure what it means i.e."4K Passthrough' does this mean it will let the video source just go thought not mess with it ? ... at all ? ... or are some passthrough's not as good as others and do mess with it ........ and what about the sound, or this about sound
I'm not sure what you mean by this sound also I meant sony and not nosy lol, the 4k passthough if a true passtrough will not touch the signal, that is correct. It will only take its sound signal from it to use for the receiver. The difference when talking 4k is that a receiver with 1.4 HDMI will passthrough 4k at 24/30 fps max and a HDMI 2.0 receiver can do it in that as well as 60fps (if the source can handle it).
Hope this helps answer at least some of your questions.
EDIT: CNET explains it well here. HDMI 2.0: What you need to know - CNET
let me try ask this again because I still don't quiet get it, so the term pass-through doesn't mean it will pass-through unchanged, but it will past through to best of the ability of the said AV which will most probable be HDMI 1.4 or lower fps than 4K, so 4K pass-through of a lesser AV or most things on the market at the moment that state 4K pass-through would reduce picture quality? yes
