Windows 7: ManyCam Issue (Audio Issue)
12 Jan 2015   #1
LaptopTech
Windows 7 64 Bit
Hi, I am trying to play music via the Audio tab within ManyCam through a broadcasting website, but when I set it up to play and then I start broadcasting, the music sounds all distorted, staticy and double playing. What am I doing wrong? Do I have to change something in my sound settings?
13 Jan 2015   #2
LaptopTech
Windows 7 64 Bit
anyone?
16 Jan 2015   #3
LaptopTech
Windows 7 64 Bit
Can someone help me out or no? Basically I need a fake webcam software that enables me to broadcast with a custom display, and allows me to play music through my computer which when people watch my cam, its clear music that they can hear playing through my laptop.
With manycam, I seem to be having an audio settings issue which when I choose "System Sounds" - it makes the music sound all weird.
16 Jan 2015   #4
LaptopTech
Windows 7 64 Bit
Ok so I muted my laptop microphone incase that was causing it to echo on the system sounds option, but it doesnt sound staticy now, but it still echoes when I watch myself. Its like its playing it twice at the same time. What could be causing this?
DPC latency issue (audio lag)
Hi, I've recently started noticing significant audio issues (lag, stuttering, static) when browsing internet, both on chrome and firefox, win7 64. It occurs when the browser is loading new content. After some googling, I've found out it is most likely related to DPC latency caused by some driver...
Drivers
Issue with Audio Redirection
Alright, this might take awhile to explain, so I'll split it into two parts: my issue and what I have tried. Issue: A nice feature of Windows 7 that I realized was that when I plug my headphones into the front audio jack, sound would of course play through the headphones but also the sound...
Confuse on Audio Issue...
I'm been reading about Windows 7 audio issues from different sources but never understood how they could help me with my problem. I'm using a software that recored from audio sources, in the soundcard area it shows devices which I selected mine and the only input source I can selected is Master...
audio issue
audio works fine on everything except internet, if i try to watch any video on youtube or yahoo, no audio. cds play fine, system sample music works fine. i'm puzzled!
Manycam Audio Broadcast.
I'm trying to broadcast my manycam stream live to the internet. Thing is my manycam will not play audio. My laptop for some reason does not have stereomix and i have followed the step's to show disabled devices etc but still nothing. I have the latest sound driver's too. Desperate help is needed...
Drivers
Audio Issue
This may be just ignorance on my part, and I'm going to sound very computer illiterate but.. I'm having an issue with the sound for my pc. currently, my speakers plugged into the green slot work fine, but my monitor's audio, plugged into the monitor with a green plug and then plugged into the...
