Windows 7: Realtek ac 97 audio problem... help!
05 Nov 2009   #1
diabetic201
xp
Realtek ac 97 audio is what the motherboard disk has on it.
i've tried to vista and xp driver on the disk, but doesn't work.
i've tried to download a windows 7 driver from this forum and it doesn't work... wondering if vista and win 7 drivers are similiar.
i can't connect to the internet because the pc is at work...
I'm working on a home build pc with windows 7 ultimate.
it's my 1st experience with win 7.
It has a msi 945 neo 2 motherboard.
1.5 tb hdd. etc.
2 gig of ram.
everything works fine except no sound.
device manager shows that all the drivers are functional.
the audio driver.... shows that it's working, but no sound.
i've uninstall and reinstall several times.
i'm about to give up... but wanted to see if anyone has any suggestions.
thanks if anyone can help.
05 Nov 2009   #2
Saltgrass
Windows 7 x64
Have you gone to the MSI site to download drivers for your motherboard.
Is this the right motherboard. If it is, I would download the Chipset and Audio and any other drivers you might need, then you will not have to go back to the site.
MSI Global ? Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more
05 Nov 2009   #3
thefabe
it is very helpful to fillin your system specs. so others can more easily help Thanks Realtek ac 97 audio problem... help!-usercp-1.png
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Other solutions for Realtek HD audio problem?
I've tried Googling this and posting in a Realtek-specific forum. This computer at work has begun to distort all the audio I hear via ear buds. Crackling, snapping, buzzing; I've never heard this type of distortion anywhere else. Since it developed over time, I thought it might have been the last...
Drivers
Realtek HD Audio EQ settings problem
Hello. :) i have a problem with Realtek Preset EQ when i change the EQ settings .. it works perfectly while playing a song but when i close the audioplayer and restart it again the EQ settings back to it's default so.. how can i save this settings and make it work everytime i lunch a media...
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Problem with Realtek HD Audio
Hi guys, hope someone can help me. I just installed Windows 7 Professional on Acer aspire m1610 which using SIS672 chipset and built in Realtek HD audio. The latest driver from realtek is R2.41 for vista & 7. So I downloaded it and install.But there's some problem when playing music or sound.It...
Realtek HD Audio problem
Hi, I'm having a few problems with certain sound drivers in windows 7. I recently done a clean install of Windows 7 and my sound is quite crackly. In Vista everything was fine and I had the Realtek HD audio software installed. Now whenever I try to install the same software it says there is...
