Windows 7: Front Audio Jack, right sided speakers/cup not working
16 Jan 2015   #1
Artekis
Windows 7, 64 Bit
Hello, I'm Artekis. A year ago, sevenforums helped solved my BSOD problem! Now I'm back for help on audio problems.
I recently noticed that the front audio ports of my Windows 7 PC do not work properly. I plugged in both speakers and my headset, and the right side of the speakers do not work as well as the right side of the headset cups.
The back audio ports work perfectly fine for both my headset and speakers. As a result, I can safely say that it's a problem with my front audio ports.
According to the Sound tab, I have VIA HD Audio, which is integrated audio on my ASUS motherboard. There also seems to be NVIDIA High Definition Audio in the sound controllers section of the device manager. According to some people on Sevenforums, it's used if you want to use a HDMI cable to connect audio from my PC to the TV? Is this correct?
So what should I do to get my front audio ports to work? I will gladly provide any information that can help solve my problem.
Thanks,
-Artekis
Edit: Just a little update, but the front audio panel worked perfectly fine from both cups of my headset for a couple of seconds after I restarted my computer. But it quickly switched back to the left cup working only. However, the mic jack in the front doesn't work at all.
17 Jan 2015   #2
fireberd
Check the front panel connection on the motherboard. Reseat the connection (unplug and then plug back in).
The front panel headphone jack may have developed a problem, which is not uncommon.
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
Front jack not working for Realtek HD Audio on Windows 7
Hi all, I've just installed Windows 7 and was very happy to see all the hardware working, even my Realtek HD Audio sound card, except the front jacks. On windows XP I could solve this by with the Sound Manager that comes with the realtek drivers, and select the "Disable front panel jack...
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
Front headphone jack does not mute rear speakers
Asus M4A78-EM motherboard using Realtek drivers from Asus site. The front headphone jack did not work until I installed the Realtek drivers from the Asus site. Actually they didnt work until I checked on Disable Front Panel Detection. That got it going but the rear speakers are still...
static from front audio jack??????
i have a acer ax1700-u3700 desktop computer. the front audio jack makes a static audio noise when moving the mouse. but when im not moving it it doesnt make noise. its worse when i click the start button and look threw the stuff on the menu. all drivers are current. upgraded bios to lastest at...
can't set front jack as default audio output (notebook)
Hi !'ve got a probelm with my compaq 615 i had a problem with my audio quitting on me after the laptop went to sleep (which required a reboot) so i reinstalled the drivers (IDT HD) now my laptop speakers are set as the default audio device and my headphone jack is set as the default...
