Windows 7: Realtek HD Audio - No Sound through speakers \ headphones
18 Jan 2015   #1
alaud
Windows 7 64bit Home
This is driving me mad now also as soon as I google it there seems to be hundreds of similar problems..
New custom PC and cant get any sound from the rear speaker jack of front headphone jack. Sound is playing as the volume leve indicator is moving up and down and is green yet no sound outputted.
Tested speakers and headphones on another machine.
Re installed the hd audio driver.
Disabled and enabled driver.
Disabled the nvida hdmi sounds drivers.
Made sure the realtek driver is default.
Checked bios has onboard sound turned on.
Now i dont seem to be getting anywhere very annoying. Please help
Many thanks,
adam
18 Jan 2015   #2
fireberd
I just went through this with another user and a Gigabyte motherboard. Never really resolved it as the user didn't want to do a complete reinstall. Everything else had been done and the user still had the problem.
However, lets try on yours.
First thing, go to the Device Manager, RIGHT click on the entry for the RealTek sound and then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound.
If that does not fix it, uninstall the RealTek in the device manager but ALSO Uninstall the drivers. Then restart and when Windows starts, it will install the sound but it should be with the generic Windows "High Definition Audio Driver". See if the sound works with this configuration. If it does, it sounds like the RealTek driver you have may be corrupt. Download the R2.75 High Definition Codecs driver direct from RealTek and see how that works. www.realtek.com
18 Jan 2015   #3
alaud
Thanks very much i will try this and let you know. Seems to be lots of problems with this realtek hd but each issue ive read online seems slightly different. Dosnt sound like a very good product.
18 Jan 2015   #4
fireberd
I have RealTek on my two custom built desktops which dual boot Win 7 64 bit and Win 8.1 64 bit and on a Lenovo Laptop with Win 7 64 bit. Works fine on all three.
18 Jan 2015   #5
alaud
I tried as you said and still no joy. Really not sure what to try next.
18 Jan 2015   #6
alaud
Very strange, it even detects when the headphones or speakers are unplugged I haven't re-installed the R2.75 High Definition Codecs driver should I do that or is there another generic driver I could try.
Not sure if it helps but the pv has rear and front casing audio jacks.
18 Jan 2015   #7
fireberd
The rear motherboard I/O panel jacks and headphone and mic jacks on the case front panel is standard.
Two things I missed to check first. (1) The "Speakers" need to be set as the Default Audio Playback device. If it is not set, but digital, for example, is set as the default playback device it could cause what you are seeing (not hearing). (2) What is listed in the Device Manager, Sound section? You should ONLY have the RealTek and possibly NVIDIA Sound (for HDMI) listed.
Assuming the Speakers are set as the default playback device, it really sounds like a Windows OS problem rather than the RealTek. If uninstalling and using the generic Windows High Defintion Audio drivers (Codec) does the same thing, that absolves RealTek as the problem. A low chance its a hardware problem with the RealTek hardware on the motherboard.
One other thing to try, just in case the front panel is causing the problem. Power off the PC first. Open the case and unplug the Audio Connection to the motherboard front panel. It will probably be labeled HD Audio (but could be labeled AC97 if you are using the older connection). Power up and see if that affects anything.
If not, you are down to two options, (1) a complete reinstall (2) A hardware problem.
You could try a separate sound card, to see what happens. There are some relatively inexpensive sound cards (or USB connected sound cards) that won't break the bank for testing. If you want to try that, disable the on-board sound in the BIOS when you do so there are no conflicts.
18 Jan 2015   #8
alaud
In device manager i currently have
High definition audio device
nvidia High definition audio
nvidia virtual audio device
I will try removing the front panel connection now.
If you google search the problem there seems to be loads of issues you must be very lucky that your 3 work
https://www.google.co.uk/search?q=re...sm=93&ie=UTF-8
19 Jan 2015   #9
fireberd
There are lots of issues with anything if you do a Google search. The RealTek audio is the prevalent hardware module used by manufacturers so there can be more posts about them.
I have a recording studio and I see the same thing about some of the more popular recording programs or hardware.
The NVIDIA Virtual Audio Device has been a problem for a few (not all but some). Try disabling that, then restart the PC and see if makes any difference.
20 Jan 2015   #10
BlindPixel
I had problems with this myself as well. I had upgraded my Power Supply on my computer with one I got from a neighbor. At the time I didn't realize it was from a computer that kicked the bucket. It worked fine for a little while, then suddenly I always heard static when using the sound. It was really annoying static that I just couldn't stop hearing. Eventually I just got myself a new sound card and that has worked out just fine.
The Realtek HD audio was through the built in sound card on the computer. I think when I upgraded the computer with the Power Supply, it blew out my sound card. I am just lucky it didn't crash my computer.
Realtek AC'97 Audio - Cant hear any sound from headphones or speakers.
I just bought a pc, windows 7 32bit. I tried to use my headphones but couldnt hear any sound, also tried speakers still no sounds. The green bar goes up on the volume control tho. I have tried downloading some drivers, but they didnt work. Im a novice when it comes to things like this, can...
Realtek HD audio recognizes my headphones as speakers
Hello When I plug in my headphones to the back of my computer where my onboard soundcard is located, it seems that realtek detects my headphones as speakers, and as a consequence, the volume is way too low. When connected to the front of my computer however, realtek detects my headphones...
Realtek HD Audio Problem: Headphones appear as "Speakers"
Dear all, my speakers do work. When i plug in my headphone at front the speakers get replaced, means I head everything through the headphone. Headphones themselves aint shown under "Sound": It appears that both, speakers and headphones are used as one source for audio-out. However, I...
realtek audio not detecting speakers or headphones.
I have an Asus M4A89TD pro / usb3 that has Realtek audio onboard. I have just finished my build and have never been able to get any sound from any of my IO ports. None of the ports recognize anything that I plug in (i only have 2 sets of 2.1 speakers, one uses a single light green jack and the...
Audio Service Not Running/No sound/No speakers/Realtek problem
I'm hoping someone can help me.I'm working on a custom pc that my brother built for me. The specs are in my signature. I recently upgraded from 32 bit to 64 bit Windows 7 home premium (I know it's not the best, but it's what I could afford). I did a drive reformat also. Initially, everything...
Audio devices undetected. Headphones or Speakers give no sound
Hi, I recently went into my computer to install a Corsair H80 Water pump for the GPU. Anyhow, after i connected all the cables and turned on the computer again i did not have any sound. Even though im not an expert with computers, i'm pretty sure all the cables are connected right (but there is...
