Windows 7: Audio problems in web browsers
05 Nov 2009   #1
Does anyone else have distorted audio when in a web browser?
For example, my systems sounds and mp3s work perfectly BUT once i get on Mozilla and try to view a video such as on youtube or a link on facebook the sound becomes distorted. some of the problems include the music may be really loud and the voices are very quiet or just everything is really distorted. i thought it may be just Mozilla so got on to internet explorer but i experienced the same problem.
does anyone else have this happen to them?
05 Nov 2009   #2
Windows 7 x64
You might see something if you start the Windows Help and Support and type in codecs. Maybe you are missing some or have different ones you might need to try. If you know the type of file being uncompressed, it might help.
Search this Thread:
Advanced Search
No audio in any browsers in Win7
About a week ago, I lost audio in my browsers. Everything was fine then bam. I can play VLC, Cd,DVDs and don't have a problem, but I cannot hear anything online. I am not sure what happened. I did a lot of trouble shooting. I tried to update drivers, but it's going for the Windows one. I did...
Hardware & Devices
Strange all browsers loading problems
I had upgraded to 8mbps plan with my broadband provider couple of months back, earlier I was on 4mbps. Ever since, I have upgraded my plan, I have been having strange loading issues with lots of sites. When I first try to load up the site, I get Problem Loading Page (error msg changes...
Browsers & Mail
Problems installing browsers
I am facing some issues with installing browsers such as Chrome and Opera on my laptop. Opera has been installed but every time I want to use it, it shows an error message that can not get started, after several attempts it starts but doesn't show any pages. I have made a screenshot so you can...
Browsers & Mail
Two browsers, two problems
Hi folks, I tend to experiment with browsers and am currently using Chrome Dev build 10.0.648.18,Opera 11.11 and Firefox Minefield. Normally Chrome has been the most used but with the latest Dev builds, in fact for several builds now, I can't figure a way to display the url address. The...
Browsers & Mail
Problems connecting to internet with programs other than web browsers
Hi All, I apologize if that subject line is slightly confusing. I will do my best to lay out my situation. I just recently did a clean install, upgrading 32bit Vista to 64bit Windows 7. I am currently using Firefox to surf the web, and it works fine for the most part. At some odd instances...
Network & Sharing
Some problems with browsers.
I am running windows 7 32 bit. I cannot start either Chrome or IE8. The only browser that I can open is Firefox 5.0. However many times Firefox freezes and i have to close it and open Firefox again. It seems to affect some websites more than others. One is a sports message board and the other...
Browsers & Mail
