Windows 7: Reoccurring low sound issue affecting two sound cards
30 Jan 2015   #1
Sakonosolo
I had this issue before, all of a sudden the sound coming from my computer gets really quiet even though everything is maxed out. Before, it seemed to have been triggered when I moved my computer from one room to another. I wasn't able to move it back right away but when I did it was still happening. I removed the sound card I have, replaced it, tried different PCI slots, tested my onboard sound card, etc but to no avail. Eventually it fixed itself and I have no idea what caused it.
Earlier today my sound was working perfectly fine. I left my computer (on the entire time) to do other things and when I got back to it the volume is again really low. When it was happening before the sound seemed to be crackling on higher volumes but there's no crackling that I can hear this time. I again tried my onboard sound card and the issue was also affecting it. I normally use headphones but also tried speakers and the issue is still there on them too. Like I said though, my computer was on the entire time I was gone and nothing was changed but this suddenly started happening.
Considering it's affecting both sound cards I imagine it has to be an issue with something else, like my motherboard or Windows 7 itself. I wasn't able to find what was causing it last time though so honestly I have no idea.
Edit: Update, I found a pair of USB headphones and their volume seems fine. I hope this means something. I assume that with USB it's not going through either sound card (though that doesn't make too much sense to me) but what that means I don't know.
31 Jan 2015   #2
ICIT2LOL
Hello and welcome Sakonoso now to me it seems that the audio through the USB port might be coming from the board audio and not the sound cards hence why it is ok. Having said that usually the on board stuff is usually cut off if there is a sound card installed.
Now it seems to narrow it down a little if this is the case and there are some things you can run sfc and a chkdsk to see if there is anything going on in the system
http://www.sevenforums.com/tutorials/139810-sfc-scannow-run-command-prompt-boot.html
http://www.sevenforums.com/tutorials/433-disk-check.html if you need to - run the latter using the /f and /r "switches"
The other thing to do is update the drivers if you havenít done so already
http://www.htomega.com/downloads.html
31 Jan 2015   #3
Sakonosolo
Welp, I was using the USB headset all day and just tried my third party sound card again and it's normal volume again. Do you have any idea if disk errors (like the ones you were telling me to use commands to look for) could resolve themselves automatically like this? Honestly to me it sounds like that telephone setting that will automatically lower the volume acting out of line but I checked that and I couldn't find any way to fix it. And I don't know if it would have affected a USB headset.
31 Jan 2015   #4
ICIT2LOL
Hmm sorry late reply mate but myself I think those checks if you ran them have sorted the problem as I really don't think the telephone settings would have anything to do with the sound cards.
I reckon it is probably the driver for the card has got put out of whack by perhaps some shut downs that have occurred by accident or power outage (what is commonly called an illegal shutdown) . Those sorts of things do by their very nature do put parts of files out of place when they happen, and soon fixed with those scans so something to keep in mind if it happens again plus a lot of usage over time does defrag the disk as you will know that is another issue that will eventually cause the files to become "undone"
By the by are you using Blu tooth phones or other devices with the machine? I know in my car the volume of other stuff is affected by incoming calls etc.
01 Feb 2015   #5
Sakonosolo
Well I actually didn't run either of the tests you linked in your other post. It just fixed itself.
I do occasionally get power outages that shut my computer off, so that might have caused something. But it's not like the issue occurs right after one of those happens. And reinstalling the driver hasn't helped either time this issue has happened.
I have two of my three drives (not the SSD) defrag every once in a while automatically.
The phone setting is what I was talking about that will automatically lower the volume or mute the volume when you get a call apparently. I'm not using any phones with my computer though but I've seen other posts complaining that that settings will sometimes trigger when it's not supposed to.
01 Feb 2015   #6
ICIT2LOL
Ok well all well and good glad t is fixed.
Now if you can run your budget to a USP then it will save any such outages affecting the system but they are not that expensive out here typically $130 but worth it for peace of mind
03 Feb 2015   #7
Sakonosolo
Okay so the problem came back just now and I did both of the scans that you suggested above and no errors were found. What else can I try to determine/fix the issue?
Play two seperate sound sources using two sound cards on one PC?
I've got one W7 PC, with one Creative X-Fi soundcard in it, on a motherboard that has built in audio. I'd like to play two music tracks on my PC at the same time, using any browser or browsers. I'd like one track to be heard on one set of speakers, and the other track to be heard from another...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Which of my sound cards is better?
i have an on-board and installed sound card that both can do pretty much the same thing, but my on-board supports 24bit 192000 Hz (max) Newegg.com - ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard and my installed sound card supports 24bit 96000 Hz (max) Newegg.com - Creative Sound...
Sound issue (Conexant sound driver)
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know! So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember,...
Sound skips after some time (tried diff. sound cards)
Hello, I used to have Vista on this computer and didn't have audio problems. I've upgraded to Windows 7 and use the latest drivers available for my sound card (Striker 7.1). I have also tried not using these drivers and instead using a USB sound card (Sennheiser that comes with one of their...
